Trouble Loging in, says login failed, what login info do I use? New User!
First time setting up a node!
The page name.local/allmon3 Allmon3 Monitoring Dashboard, on the left side it says Home, Node#, and Login.
I am trying to login, I am assuming my login username and password is the same as the Web admin portal...
I can log into the Web admin portal, but when I try to log into Monitoring Dashboard, it says login failed..
Am I using the correct login info?
Have a look at :
Thank you! That worked!
I don't think my node itself is connected or not transmitting, I connected to a node link, but I am not getting response from my radio.... I will need to go through the instructions again..
