Trouble connecting to allstar nodes
In the last few days having issue with connecting to Allstar nodes everything work fine then suddenly it didn.t
While on the surface, this may not seem to be a issue, please read all of this and perhaps you might figure out what is happening.
Being intermittent, it sure sounds like it could be.
https://wiki.allstarlink.org/wiki/Private_nodes
Other possibilities are node list updates at either your server or the intended target server. But I doubt that.
Callsign? Node Number? Can’t help much without that info.
Jim, K6JWN
The call sign is Vo1DNK node 43386
Ok, I see the node online. What happens when you try to connect to other nodes?
Jim, K6JWN
I see the issue. You configured a proxy IP address (which I assume is the IP address of your node on your network) in the server configuration in the web portal. Go in and remove it, give it about 10 minutes for the correct IP address to re-propagate through the network.
That should resolve your connection issue. If you need help doing that, please open a helpdesk ticket and I’d be glad to assist there.
Jim, K6JWN
How do i get into fix it thanks
Thanks for you help problem solve!
No problem! Glad you were able to get it fixed.
Jim, K6JWN
