Trixie Cockpit Splash Screen
I updated two identical Trixie nodes on Oct 17 and Oct 27. One has the old pea soup splash screen and the other has this new Star Galaxy splash screen. Why are they not the same?
Roger
WA1NVC
Are both on the "devel" package stream? That splash screen should only be available in the "devel" repo currently.
How would I know if I'm on the "devel" repo?
Is this a node setting on the ASL page or something I do on the node itself?
I did notice that the number of updates installed on 10/27 was different: 32 vs 12. I thought that was strange since both had been updated at the same time on 10/17.
Roger
WA1NVC
Just run asl-repo-switch. If you're on devel it'll look like:
# asl-repo-switch
trixie: main beta devel
Yes, I get:
repeater@node60861:~ $ sudo asl-repo-switch
How did I get into this state?
Can I undo this or should I just re-image and restore from backup?
(fast solution?)
This node was about to go to a site that only gets visited about once a
year.
Roger
WA1NVC
ยทยทยท
On 10/28/2026 10:57 AM, N8EI wrote:
Someone replied to your post.
[N8EI] N8EI https://community.allstarlink.org/u/n8ei ASL Community Admin
October 28
Just run |asl-repo-switch|. If you're on devel it'll look like:
asl-repo-switch trixie: main beta devel |
Visit Topic <https://community.allstarlink.org/t/trixie-cockpit-splash-
screen/25128/4> or reply to this email to respond.
To unsubscribe from these emails, click here <https://
community.allstarlink.org/email/
unsubscribe/4e4f3b01eef58cdb64ab78c55c29fc5574d2bfdb69d4d5bae6df0aab9aa528b2>.
At some time, you must have exec'd :
sudo asl-repo-switch -l beta
To switch back to the main/production package stream, use :
sudo asl-repo-switch -l main
sudo apt update
For more info, check out ASL Manual / Beta Testing
I tried the following found by a internet search from the ASL manual;
BUT... ASL3 and ASL3 PI-APPLIANCE failed.
sudo apt install -y --reinstall asl3 asl3-asterisk asl3-asterisk-config \
asl3-asterisk-modules asl3-menu asl3-update-nodelist
asl3-appliance-pi allmon3
Reinstallation of asl3 is not possible, it cannot be downloaded.
Reinstallation of asl3-appliance-pi is not possible, it cannot be
downloaded.
Looks like rebuild from scratch.
I noticed that this happened to another pi-appliance user also.
Roger
WA1NVC
ยทยทยท
October 28
There's no reason to rebuild. What I would suggest you do is leave the system on devel. There's nothing broken with the devel packages - the are stable and they're going to be moved into beta by the weekend. Once they're moved to beta and you see the announcement, move your system to beta using asl-repo-switch -l beta && apt update. Just let it roll for a few days.
In fact, you'll like the new UI if you browse to /asl-web-ui/ on your system :slight_smile:
Jason
I have some how inadvertently got onto the development channel on one of my production gateways the other night (I've never opted in so no idea how it happened) so I've got the new UI showing up which is fine, everything seems to be working but it appears to have broken third party integrations that hook into Allmon3.
For example I installed AllstarLink Hearald from GitHub and whilst it's installed ok I cannot reach it's admin pages when logged into Allmon3. This is what I see:
so when I click on Announcement Manager in the sidebar I just get the page with an error.
Any idea how to fix? Hopefully it's not too serious. I'm not that familiar with linux but can find my way around a little. I had the same issue with another announcement manager plugin in allmon so whatever has changed seems to have broken whatever hooks into this.
Simon
Likely whatever that system is, it's inappropriately modifying a configuration file or location that is controlled by the appliance. You'd need to talk to whomever makes that app for a resolution.
Something similar happened to my app, announcement- manager. I can't speak to this app on whether it is modifying any files,
But mine is not modifying any asl files. You need to move your announcement- manager folder from /var/www/html/announcement-manager to /usr/share/asl3-appliance/web and it will work. The web server has been moved. Of course you need to create the announcement- manager folder to put them in. My install script will be updated to handle this for both systems.
No, don't do this because the appliance package manages that directory.
Your files should be installed in /usr/local/share/asl-tts-announcement-manager or /var/www/asl-tts-announcement-manger. The in /etc/apache2/conf-available/asl-tts-announcement-manager.conf you have something like:
## Configuration for the asl-tts-announcement-manager application
Alias /announcement-manager /usr/local/share/asl-tts-announcement-manager
## Uncomment for .htaccess support
#<Directory /usr/local/share/asl-tts-announcement-manager>
#        AllowOverride all
#</Directory>
After that do a2enconf asl-tts-announcement-manager followed by systemctl reload apache2. This is how you install modular software properly into Apache regardless of ASL or not. And since it follows the standard convention, the ASL3 Appliance packages - which also follow the standards - won't mess with it.
This is happening to my node, as well. I just posted about not being able to get Allscan to work. I don't know how my node was switched to this state. All I did was update ASL3, as I always frequently do and now Allscan doesn't work by returning the message:
404 Not Found
The requested URL was not found on this server.
Apache/2.4.69 (Debian) Server at 192.168.1.169 Port 443
Doesn't the webpage fit my app need to be in the webserver path in order to show up in the iframe?
ยทยทยท
Sent: Friday, 30 October 2026 09:16:56
To: [email protected] [email protected]
Subject: AllStarLink Community Forum: Trixie Cockpit Splash Screen
N8EI ASL Community Admin
October 30
N5AD:
#        AllowOverride all
#</Directory>
URI path yes, on-disk filesystem path no. That's what the Alias statement does.
Will this change also work on the legacy sysem? Or this new one only?
ยทยทยท
Sent: Friday, 30 October 2026 10:51:18
October 30
Using configuration snippets for applications in /etc/apache2/conf-available is how this has always worked in Debian from time immemorial. If the available site is "default" in /etc/apache2/sites-enabled then the conf.d snippet is essentially a no-op. If it's ASL3 Appliance's version (or literally any other configuration), then the right thing "just works" because the configuration points it back to the right location. You could even keep it at /var/www/html/announcement-manager and just update the .conf snippet appropriately.
Thank you for the feedback. I'll work on that once i get home this evening.
asl3-asterisk*-3.0.1-1 is now in the devel repo for testing for this issue.
Announcement-manager has been updated to reflect the recommendations. It has been tested on numerous nodes and is working as it should. Old installer files should be removed and the new installer from my repository at GitHub - n5ad/announcement-manager: Supermon 7.4+ announcement creation and management of cron entries ยท GitHub should be downloaded and ran. it will update all locations and permissions.
