Transmitter sticks
OS Kernel : 6.12.47+rpt-rpi-2712
Asterisk : 22.5.2+asl3-3.6.3-1.deb13
ASL [app_rpt] : 3.6.3
Installed ASL packages :
Package Version
allmon3 1.7.0-1.deb13
asl3 3.12-1.deb13
asl3-appliance 2.0.1-2.deb13
asl3-appliance-pi 2.0.1-2.deb13
asl3-asterisk 2:22.5.2+asl3-3.6.3-1.deb13
asl3-asterisk-config 2:22.5.2+asl3-3.6.3-1.deb13
asl3-asterisk-modules 2:22.5.2+asl3-3.6.3-1.deb13
asl3-menu 1.16-1.deb13
asl-apt-repos 2.0-1.deb13
cockpit 337-1
cockpit-bridge 337-1
Inquiry
My transmitter is getting stuck on at random times. It seems to happen (the few times I’ve heard it) it’s when someone is talking, and then it just goes dead, but the transmitter does not unkey. I don’t know if this is a receive failure or a transmitter problem??
Any suggestions?
It appears that you are using a Raspberry Pi. How about some info about your radio configuration?, URIs?, and your SimpleUSB / USBRadio settings?
Did you already solve this issue?
I ran into the same.
I believe so.
in the simpleusb.conf there are settings for rxdelay and txdelay. I set both to 40.
If you still have issues, it is suggested to set the audio to 500 or less, but mine already was at 500.
Good luck!!
