Transmit issues
A bit frustrated this morning. Node 46857, latest image install on an RPi 3, all updates (update/upgrade) performed. Allmon2 installed and working fine. SimpleUSB through a CM FOB, connected to a 888s (however radio is most times turned off). Yesterday was adding my phone hotspot to the wireless configs and testing through both to make sure it was working by connecting to node 2560 in listen mode. I was controlling through Allmon2, with radio attached, but not transmitting. After I was all done I tried to connect to WINS on 2560 and was rejected, several times - eventually was contacted and told I had keyed down the system 3 times, a couple minutes each. Odd thing was as I said I never transmitted. I checked messages log and did not find anything other than the usb not being ready at startup, but eventually it does start about 15 sec later and no other messages after.
Later last night I connected to 2560 (after being un-banned) and listened to almost an hour of the insomniac net, controlling through allmon2 and listening via android iaxrpt. All the time watching the Asterisk cli, then checking after I disconnected the tail of the messages log. All looked fine.
This morning (node on all night, not connected to any other node, radio off). Connected to 46857 via iaxrpt desktop and used macro to connect to 2560. Not 10 min later I noticed I was not hearing anything from iaxrpt. Opening Allmon2 I saw I was disconnected from 2560 again. I received an email that I was keying the system again… I wasn’t touching anything or doing anything config wise. I did have the cli open, here is what it said:
Verbosity is at least 3
– Accepting AUTHENTICATED call from 192.168.1.129:
> requested format = gsm,
> requested prefs = (),
> actual format = gsm,
> host prefs = (ulaw|adpcm|gsm),
> priority = mine
– Executing [46857@iaxrpt:1] Rpt(“IAX2/iaxrpt-6390”, “46857|X”) in new stack
== Spawn extension (iaxrpt, 46857, 1) exited KEEPALIVE on ‘IAX2/iaxrpt-6390’
== Refreshing DNS lookups.
– Call accepted by 173.82.59.253 (format ulaw)
– Format for call is ulaw
– Hungup ‘DAHDI/pseudo-714478141’
– Hungup ‘DAHDI/pseudo-104883990’
– Hungup ‘DAHDI/pseudo-1905028877’
– Hungup ‘DAHDI/pseudo-1251358383’
– Hungup ‘DAHDI/pseudo-547114662’
– Hungup ‘IAX2/173.82.59.253:4569-1730’
– Hungup ‘DAHDI/pseudo-605528485’
– Hungup ‘DAHDI/pseudo-553835508’
– Registered IAX2 ‘android-iaxrpt’ (AUTHENTICATED) at 192.168.1.107:35074
– Accepting AUTHENTICATED call from 192.168.1.107:
> requested format = ulaw,
> requested prefs = (ulaw),
> actual format = ulaw,
> host prefs = (ulaw|g726aal2|gsm),
> priority = mine
– Executing [46857@phone-iaxrpt:1] Rpt(“IAX2/android-iaxrpt-7544”, “46857|P”) in new stack
== Spawn extension (phone-iaxrpt, 46857, 1) exited KEEPALIVE on ‘IAX2/android-iaxrpt-7544’
== Manager ‘admin’ logged on from 127.0.0.1
– Registered IAX2 ‘android-iaxrpt’ (AUTHENTICATED) at 192.168.1.107:59606
– Registered IAX2 ‘android-iaxrpt’ (AUTHENTICATED) at 192.168.1.107:53095
[Mar 27 08:02:20] WARNING[584]: chan_iax2.c:3101 __attempt_transmit: Max retries exceeded to host 192.168.1.107 on IAX2/android-iaxrpt-7544 (type = 6, subclass = 2, ts=2477969, seqno=113)
– Hungup ‘IAX2/android-iaxrpt-7544’
– Hungup ‘DAHDI/pseudo-1835956150’
– Registered IAX2 ‘android-iaxrpt’ (AUTHENTICATED) at 192.168.1.107:40182
– Registered IAX2 ‘android-iaxrpt’ (AUTHENTICATED) at 192.168.1.107:51207
– Registered IAX2 ‘android-iaxrpt’ (AUTHENTICATED) at 192.168.1.107:46617
– <DAHDI/pseudo-491804915> Playing ‘rpt/node’ (language ‘en’)
– Hungup ‘DAHDI/pseudo-868072667’
– Hungup ‘DAHDI/pseudo-1469835999’
– <DAHDI/pseudo-491804915> Playing ‘digits/2’ (language ‘en’)
– <DAHDI/pseudo-491804915> Playing ‘digits/5’ (language ‘en’)
– <DAHDI/pseudo-491804915> Playing ‘digits/6’ (language ‘en’)
– <DAHDI/pseudo-491804915> Playing ‘digits/0’ (language ‘en’)
– <DAHDI/pseudo-491804915> Playing ‘rpt/connected’ (language ‘en’)
– <DAHDI/pseudo-491804915> Playing ‘digits/4’ (language ‘en’)
– <DAHDI/pseudo-491804915> Playing ‘digits/8’ (language ‘en’)
– <DAHDI/pseudo-491804915> Playing ‘digits/7’ (language ‘en’)
– Hungup ‘DAHDI/pseudo-491804915’
– Hungup ‘DAHDI/pseudo-1496043418’
– <DAHDI/pseudo-788169365> Playing ‘rpt/node’ (language ‘en’)
– <DAHDI/pseudo-788169365> Playing ‘digits/2’ (language ‘en’)
– <DAHDI/pseudo-788169365> Playing ‘digits/5’ (language ‘en’)
– <DAHDI/pseudo-788169365> Playing ‘digits/6’ (language ‘en’)
– <DAHDI/pseudo-788169365> Playing ‘digits/0’ (language ‘en’)
– <DAHDI/pseudo-788169365> Playing ‘rpt/connected’ (language ‘en’)
– <DAHDI/pseudo-788169365> Playing ‘digits/4’ (language ‘en’)
– <DAHDI/pseudo-788169365> Playing ‘digits/8’ (language ‘en’)
– <DAHDI/pseudo-788169365> Playing ‘digits/3’ (language ‘en’)
– Hungup ‘DAHDI/pseudo-788169365’
About 2/3 of the way down you see where the system was transmitting telem - this has me confused also this is where I turned on the radio… why did that start playing then? After it started going into the 2nd set of info I just pulled the plug.
Ok, sorry about writing a book here, but I am quite confused as to why the system keeps keying down that node - is there a more detailed log that someone can point me too… I am at a bit of a loss and honestly a little afraid to connect to anything at this point.
Thoughts?
Stacey - KB7YS
