Transition to two node system questions
Hi,
I have a second URI that I want to bring up on my rpi2 server, and I have some questions. I am following the directions at: http://docs.allstarlink.org/drupal/node/139 , and there are some differences I want to ask about.
The instructions say:
  1. Edit the usbradio.conf file. Make a copy of the [usb] stanza in usbradio.conf.
  2. Paste the copy just below the original stanza.
  3. Rename the stanza name of the copy to [usb1]
    but I am actually seeing [usb12345] (node number). Should I just duplicate this format since there is no [usb0] and [usb1]?
Also, in some of the files I see other info that I could duplicate that is not specified in the howto. For example,
  1. Edit the extensions.conf file
  2. Add the 5678 extension in the radio-secure context to call the rpt application using the new node number:
    [radio-secure] exten => 1234,1,rpt,1234 exten => 5678,1,rpt,5678
    I have made the edits above, but should I also add the lines below also for my second node number? The howto doesn’t say I should, but it looks like I might want to.
[radio-secure-proxy]
exten => 1234,1,rpt,1234|X
exten => 5678,1,rpt,5678|X
exten => _0X.,1,Goto(allstar-sys|${EXTEN:1}|1)
Doug
KI7DQG
Doug,
Yes, duplicate the format. it just has to be unique and match what
you define in rpt.conf
Yes, you can make the same changes to radio-secure-proxy.
73, Steve N4IRS
On 06/06/2016 06:12 PM, Doug Fessler
wrote:
Hi,
server, and I have some questions.� I am following the
directions at:�http://docs.allstarlink.org/drupal/node/139 �,
and there are some differences I want to ask about. �
  1. Paste the copy just below the original stanza.
  2. Rename the stanza name of the copy to [usb1]
    but I am actually seeing�[usb12345] (node number).� Should I
    [usb1]?
              [radio-secure]
lines below also for my second node number?� The howto
Doug
KI7DQG
1st Law of Logic
