Hi
I recently switched to a different intetnet provider. The modem I am using only has one ethernet output. My tp link wifi is using that port.
I tryed plugging my node into the hub built into the wifi router but it will not work that way. It wont connect to internet.
My olf internet system had a ethernet hub built into the cable modem. the node would work that way. The new way going through the tp link router
I and not even use putty to access the node to make adjustments. The ip address from the tp link that was assigned to my node was 174.59.131.140
i also use an app called zoiper on my phone it will not register withis this ip address,
i am stumped and my node is down until i can figure how to connect to internet,
any help woulg be appreciated. ptherwise the node is just junk to me.
