Total list of all Allstar commands
Can some one point me to a listing of every available command defined that can used with Allstar.
I am have a heck of a time trying to configure my nodes so everything is all the same commands on all my nodes..
It seems whenever there is a different version other than the 1-5 ilink commands there is no standard numbering system between versions or platforms.
Realizing that it is up to me to standardize my own system I am about to start from scratch eliminating all the jumble.
It would certainly be helpful if there was a COMPLETE command list with explanations of their functions.
Larry - N7FM
in rpt.conf, (cut and paste ) the [functions] stanza to a seperate file labeled commands.include then delete or comment out all the commands in the stanza and replace with this line “#include commands.include” THEN put all the commands YOU want above and beyond what is required to be standard across everyones nodes 1-5 ilink etc. in the commands.include file. Use (winSCP) to copy the commands.include file to all your nodes and edit each nodes rpt.conf stanza to have the line in [functions] be #include commands.include. For each new system you just you build just add YOUR commands.include file and it will have all the same commands as the others.
outstreamcmd=/bin/sh,-c,/usr/bin/lame --preset cbr 16 -r -m m -s 8 --bitwidth 16 - - 2> /tmp/stream.status | /usr/bin/ezstream -qvc /etc/ezstream.xml
[functions]
#include /etc/asterisk/local/localcmds.include
[morse]
speed=20
and a copy of a generic commands.include file for you to cut and paste if you wish.
root@N8THN:/etc/asterisk# cat commands.include
;commands.include
;Command common acrossed all nodes
;single digit public commands
0=autopatchdn
1=ilink,1 ; Disconnect Link
2=ilink,2 ; Connect Link MOnitor Only
3=ilink,3 ; Connect Link Transieve
4=ilink,4 ; Enter Command Mode on another Node
5=macro,1 ; Macro Prefix
6=autopatchup,noct=1,farenddisconnect=1,dialtime=20000 ; Autopatch up
;double digit public commands
70=ilink,5 ; System Status
71=ilink,6 ; Disconnect all Links
72=ilink,7 ; Play Last Node to Key Up
73=ilink,15 ; FULL system Status - all nodes
74=ilink,16 ; Reconnect disconnected links disconnected with disconnect all links command
75=ilink,8 ; Connect Link LOCAL monitor only
76=
77=
78=
79=
80=status,11 ;Force ID LOCAL ONLY
81=status,12 ; GIve Time of Day LOCAL ONLY
82=status,3 ; Give Software Verison
83=status,5 ; Last DTMF User
84=cop,32 ; DTMF TEST
85=
86=
87=
88=cop,55 ;Parrot Once if parrot mode is disabled
89=autopatchup,context=command_process,noct=1,farenddisconnect=1,dialtime=7000,quiet=1; Command Processing
99=cop,6 ; ptt phone mode
; Triple digit control operator /owner codes
900=cop,3 ;disable system
901=cop,2 ;enable system
903=cop,1 ;System warm boot
902=
903=
904=cop,4 ;Test Tone On/Off
905=cop,5 ;dump system variables
906=
907=cop,7 ;Time out timer enable
908=cop,8 ;Time out timer disable
909=cop,9 ;Autopatch enable
910=cop,10 ;Autopatch disable
911=cop,11 ;Link enable
912=cop,12 ;Link disable
913=cop,13 ;Query System State
914=cop,14 ;Change System State
915=cop,15 ;Scheduler Enable
916=cop,16 ;Scheduler Disable
917=cop,17 ;User functions (time, id, etc) enable
918=cop,18 ;User functions (time, id, etc) disable
919=cop,19 ;Select alternate hang timer
920=cop,20 ;Select standard hang timer
921=cop,21 ;Enable Parrot Mode
922=cop,22 ;Disable Parrot Mode
923=cop,23 ;Birdbath (Current Parrot Cleanup/Flush)
924=cop,24 ;Flush all telemetry
925=cop,25 ;Query !!!last node un-keyed!!!
926=cop,26 ;Query all nodes keyed/unkeyed
927=cop,27 ;Reset DAQ minimum on a pin
928=cop,28 ;Reset DAQ maximum on a pin
929=
930=cop,30 ;Recall Memory Setting in Attached Xcvr
931=cop,31 ;Channel Selector for Parallel Programmed Xcvr
932=
933=cop,33 ;Local Telemetry Output Enable
934=cop,34 ;Local Telemetry Output Disable
935=cop,35 ;Local Telemetry Output on Demand
936=cop,36 ;Foreign Link Local Output Path Enable
937=cop,37 ;Foreign Link Local Output Path Disable
938=cop,38 ;Foreign Link Local Output Path Follows Local Telemetry
939=cop,39 ;Foreign Link Local Output Path on Demand
940=cop,40 ;IRLP announce Enable
941=cop,41 ;IRLP announce Disable
942=cop,42 ;Echolink announce node # only
943=cop,43 ;Echolink announce node Callsign only
944=cop,44 ;Echolink announce node # & Callsign
945=cop,45 ;Link Activity timer enable
946=cop,46 ;Link Activity timer disable
947=cop,47 ;Reset “Link Config Changed” Flag
948=cop,48 ;Send Page-Tone specs separated by ( )
949=cop,49 ;Disable incoming connections (control state NOICE)
950=cop,50 ;Enable incoming connections (control state NOICD)
951=cop,51 ;Enable sleep mode
952=cop,52 ;Disable sleep mode
953=cop,53 ;Wake up from sleep
954=cop,54 ;Go to sleep
955=cop,60 ;SEND MDC-1200 Burst
956=cop,56 ;Rx CTCSS Enable
957=cop,57 ;Rx CTCSS Disable
958=cop,58 ;Tx CTCSS On Input only Enable
959=cop,59 ;Tx CTCSS On Input only Disable
; 98 series up to local nodes
I am have a heck of a time trying to configure my nodes so everything is all the same commands on all my nodes…
Larry - N7FM
Nathan Hardman
nhardman1428@gmail.com
N8THN@ARRL.NET
The sample rpt.conf that is included with AllStarLink Asterisk is my attempt to include each command available. For the numbering system, except for a few commands, there is no standard. That is up to the node operator. The sample rpt.conf is at <https://github.com/AllStarLink/DIAL/blob/master/configs/rpt.conf&gt; I'm sure I missed something. I would not be surprised if there are errors. As people point them out I'll make edits. We are working to fill out the wiki as the place to go for all things AllStarLink at <http://wiki.allstarlink.org/wiki/Main_Page&gt;
73, Steve N4IRS
Larry - N7FM
This needs to be called out.
If you can't code but you can write English, the wiki needs work. All you
need to do is signup online with your callsign and then start creating
content. Even if it's a minor edit, the only reason we have the accounts is
to prevent spam and defacement.
Bryan Fields
727-409-1194 - Voice
http://bryanfields.net
Thanks everyone for the feedback.
I didn't realize the WIKI was already up and running with so much updated info. All my searches including the old Drupal Site returned lists that were missing portions.
Well done Steve and to ALL that have contributed to the WIKI.
Larry - N7FM
73, Steve N4IRS
Larry - N7FM
(Remember when the Pentium was discovered to have a bug that
approximated the mathematical results of some computations?
Yeah…that long ago)
  Anyway...did some digging, especially since more and more folks
are migrating to the Pi.
  But first: in order to implant these malware exploits, you have
to have access to the system. IF you are not practicing good
systems hygiene, and not keeping up to date, have a wide range of
ports open, etc…every port open is one more potential exploit.
Running web servers on the same host as app_rpt, for instance.
Having simple passwords for SSH login. Allowing ROOT login via
SSH. The list is long and ugly. But, but, but…the flexibility
of the event subsystem, macros, and dtmf functions really don’t
require anything other than the IAX2 port be opened to do 98% of
system maintenance. And if you really really need console access,
consider configuring a VPN with cryptographic id exchange. Limit
the attack surface…limit the possibility of exploit.
But, what about the Pi?
According to ARM themselves (),
the Raspberry Pi’s processor cores (for all versions) are affected.
    "The majority of Arm processors are not impacted by any
variation of this side-channel speculation mechanism. A
definitive list of the small subset of Arm-designed processors
that are susceptible can be found below.
The processor cores used by the Pis are:
of the attack (they are not listed at all, in fact, because there
is no known vulnerability to these attacks).
Spectre and Meltdown both require out-of-order execution. The Cortex-A7 used in the early Pi 2 and the Cortex A53 used in the later Pi 2 and the
Pi 3 is a strictly in-order architecture. The ARM11
used in the Pi 1 is partially out-of-order, but not in a way that
permits Spectre or Meltdown to work.
ARM confirms this : only a very limited
subset of ARM processors have hardware that makes them vulnerable
to Spectre, an even more limited subset are vulnerable to
Meltdown, and it’s believed that all of them permit mitigation of
the threat. Take that for what it’s worth.
  Bottom line, to me: should we worry about this?  Not to the point
of loosing sleep, at least on the allstar side of the house. It’s
something to be aware of, especially those running on Intel CPUs,
since the chance of it being exploited is greater than zero, but
the risk, at this point, of it happening is less than 100,
especially if you’ve locked down your ports on your ingress/egress
routers, have firewalls in place, etc., and generally practice
good system management and security hygiene.
  I'm thinking that when the necessary patches for the underlying
OS (Debian) are published, a side effort to respin the release
with the patches, after testing for performance and reliability of
the allstart code, be done and released, and that the USERS
implement the update. We can’t force anyone to do so…but, it’s
just doing the Right Thing to do so.
  Your Windows/Mac/etc desktop and office systems?  That's another
story. Keep a watch on the patch release cycles and fixes that
are offered from the software vendors. Apply them.
  Because these exploits use an acceleration feature in the
architecture to help them work faster…I’m predicting that any
software/OS patch to minimize the exposure will have a performance
hit, since it will essentially turn off a major pipeline speedup
function. So, wariness, both to prevent infection, as well as
implementing changes is certainly warranted.
Bryan
WB0YLE/W2FUV
https://developer.arm.com/support/security-updatenot
The functions in rpt.conf are touch tone pointers to the underlying command structure of app_rpt. For example 3 = ilink,3 in the functions stanza of rpt.conf means that when the touch tone function *3 is received the app_rpt command ilink 3 is executed, which, of course is the connect command.
This gives app_rpt unmatched flexibility. You could change what *3 does, although that would be ill advised. A better example would be ilink 6 which disconnects all nodes. You might prefer to use *86 rather than the current DIAL function *806 to disconnect all nodes. So in rpt.conf you would change 806 = ilink,6 to 86 = link,6.
DIAL has darn near all the app_rpt commands available mapped to touch tone functions. The complete list of all app_rpt commands is documented in the comments at the top of app_rpt.c available at https://github.com/AllStarLink/Asterisk/blob/master/asterisk/apps/app_rpt.c
On Fri, Jan 5, 2018 at 6:19 AM, Steve Zingman szingman@msgstor.com wrote:
The sample rpt.conf that is included with AllStarLink Asterisk is my attempt to include each command available. For the numbering system, except for a few commands, there is no standard. That is up to the node operator. The sample rpt.conf is at <https://github.com/AllStarLink/DIAL/blob/master/configs/rpt.conf> I’m sure I missed something. I would not be surprised if there are errors. As people point them out I’ll make edits. We are working to fill out the wiki as the place to go for all things AllStarLink at <http://wiki.allstarlink.org/wiki/Main_Page>
73, Steve N4IRS
Larry - N7FM
Tim WD6AWP
Appreciate all the feedback Tim… and all
Have the listing all archived in my files finally.
Now I just need to reconfiguring all my nodes to be identical and
eliminate the confusion.
I have quite a mix of hardware and the different firmware versions
left things in a jumble between the different platforms.
Larry - N7FM
On 01/09/2018 08:09 PM, Tim Sawyer
wrote:
      The functions
      This gives
= link,6.
      DIAL has darn
wrote:
        The sample
<https://github.com/AllStarLink/DIAL/blob/master/configs/rpt.conf >
        73, Steve N4IRS
nodes…
all the jumble.
              Larry - N7FM
              [http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users](http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users)
              To unsubscribe from this list please visit [http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users](http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users)
email address and press the “Unsubscribe or edit
options button”
              You do not need a password to unsubscribe, you can do
it via email confirmation. If you have trouble
unsubscribing, please send a message to the list
detailing the problem.
email address and press the “Unsubscribe or edit options
button”
            You do not need a password to unsubscribe, you can do it
Tim WD6AWP
So, to disable Totime at bootup, not DTMF controlled…
I did this:
;totime = 180000
totdis =
[Commented out the Totime line, and added a Totdis line with and “=” followed by blank.]
This will disable my Totime, right? Can’t find any notes as to syntax of using Totdis in rpt.conf.
Doug
The thread you replied to is very old. 8 years.
You should start a new one and state your issue and software version.
But, blanking a timer may not have the effect you might expect, for some have a default value when nothing is set. But I can not tell you which ones or what values they might be in that case.
Try to turn off the TOT (it has a settable dtmf command).
