I just reinstall all my node 27305 has been successfully checked however does not appear in the list of the stats page allstarlink.org not understand that it may be happening any ideas thanks
Uncomment two lines in /etc/asterisk/rpt.conf:
; *** Status Reporting ***
; Uncomment the either group following two statpost lines to report the status of your node to stats.allstarlink.org
; depending on whether you are running ACID or Limey Linux.
; ** For ACID ***
statpost_program=/usr/bin/wget,-q,–timeout=15,–tries=1,–output-document=/dev/null
statpost_url=http://stats.allstarlink.org/uhandler.php ; Status updates
; ** For Limey Linux **
;statpost_program=/bin/wget,-q,–timeout=15,–tries=1,–output-document=/dev/null
;statpost_url=http://stats.allstarlink.org/uhandler.php ; Status updates
Tim
:wq
ohnosec.orgTo unsubscribe from this list please visit ohnosec.org and scroll down to the bottom of the page. Enter your email address and press the “Unsubscribe or edit options button”
These two lines are active using ACID !
X
X
2014-02-10 14:57 GMT+00:00 Tim Sawyer tim.sawyer@mac.com:
; ** For ACID ***
Tim
:wq
http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-usersTo unsubscribe from this list please visit http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users and scroll down to the bottom of the page. Enter your email address and press the “Unsubscribe or edit options button”
I see your node is not registered. You can see registration by looking at https://allstarlink.org/nodelist.php. There needs to be a green background on your node number. Or you can use the Asterisk CLI (i.e. *CLI> iax2 show registry).
Registration has to happen before anything else will work including stats. Internet connectivity is necessary to register with the Allstar system. See if you can ping google.com on anything else outside of your LAN. If not it’s probably a DNS problem. New ACID installs sometimes don’t have DNS entries in /etc/resolv.conf.
It should look something like this:
nameserver 8.8.8.8
nameserver 8.8.4.4
; ** For ACID ***
Tim
:wq
How can register my node now?? Yesterday can see as registered but now appear as unregistered
2014-02-10 16:27 GMT+00:00 ea8ee ea8ee1@gmail.com:
Jim
it appear
host dnsmgr unregistered
But I dont understand two thing first yesterday my node is registered and second appear 4569 but I use 4570 as UDP
how I can to register it and change the UDP port
2014-02-10 16:02 GMT+00:00 Tim Sawyer tim.sawyer@mac.com:
nameserver 8.8.8.8
nameserver 8.8.4.4
Tim
:wq
X
X
; ** For ACID ***
Tim
:wq
Takes a while to get propagated throughout the system.
-Geoff/W5OMR
in the list of
