tmg-707 interface board
For those of you interested in interfacing a Kenwood TMG-707a
to app_rpt, check this out:
http://app-rpt.qrvc.com/node/162
JIM WB6NIL
Finally did the update to the KC0SOK Asterisk RF Gateway today and ran into a problem with the reverse patch.
It works fine calling out to the node, but when I try to initiate a call to PSTN or IP Phone the audio is muted until *98 is entered. Is there some added steps in the 0.203 package that needs to be done in order to have Pv work? The previous version that I was using worked fine with VOX on the reverse patch (0.152)
Mars, N0PCO
ALERTradio ERC
www.alertradio.net.
Mars, N0PCO
ALERTradio ERC
www.alertradio.net.
App_rpt-users@qrvc.com
Hi Mars,
Dunno--
There must be something else causing this problem. I just tested it om
my Limey linux system on node 2010 with app_rpt.c version 0.207 and it
works as advertised.
You are running a really old version of app_rpt.c.
Did you upgrade the whole asterisk source package or just app_rpt.c?
If just app_rpt.c was upgraded, try upgrading all of the sources.
Steve
WA6ZFT
