My setup is a Raspberry Pi 3, URIx (no eprom) and a Kenwood TK-820. I’m getting good audio out when I use iaxrpt, the IDs and times transmit fine, but inbound rf signals to the repeater can’t be heard and don’t trigger beeps, etc. When manually open the COS, I can hear the squelch noise and the inbound audio. Here are my settings.
Any advice on what I might be doing wrong?
Card is: 0
Name is: usb
Rx Level: 500
Rx no-delay: 0
Rx audio-delay: 0
Tx A Level: 500
Tx B Level: 500
preemphasis: no
deemphasis: no
plfilter: yes
rxboost: yes
PTT: Active LOW
PTT status: Un-Keyed
CTCSS (input): CM108/CM119 Active LOW
COS (input): CM108/CM119 Active HIGH
COS (test): Un-Keyed
COS (composite): Un-Keyed
Thanks very much for any wisdom you can share!
Scott W. - W9WSW
Scott,
I have a TKR-820 using a RA-35...
The info and symptoms your provided are kinda vague, please expand:
- what is NOT happening that should be
or
- what is happening that should not be
AND
- what connections from the URI are going where to the repeater?
AND
- What are your settings for simpleUSB.conf?
~Benjamin, KB9LFZ
I'm getting good audio out when I use iaxrpt, the IDs and times
transmit fine, but inbound rf signals to the repeater can't be heard
and don't trigger beeps, etc. When manually open the COS, I can hear
Card is: 0
Name is: usb
Rx Level: 500
Rx no-delay: 0
Rx audio-delay: 0
Tx A Level: 500
Tx B Level: 500
preemphasis: no
deemphasis: no
plfilter: yes
rxboost: yes
PTT: Active LOW
Scott W. - W9WSW
