Timeout timer COP commands announcing mnemonics globally
Asterisk Version: 22.4.1+asl3-3.5.5-1.deb12
ASL3 Version: 3.8-1
I recently uncommented COP functions 907 and 908 on my repeater and simplex nodes so the timeout timer would not time out while Amateur Radio Newsline is being played globally on my hub node. I am using entries in the rpt.conf scheduler stanza to control timing of macros I set up to disable TOT prior to ARN playing and enable TOT at a point in time after the transmission is finished. It all fires as it should and works great. However, my only issue is that the mnemonics associated with the timeout timer COP functions are announce globally. Is there a way to disable just this telemetry announcement or perhaps play it locally instead of being pushed out to all connected nodes? I currently have 3 nodes connected to the hub node and I hear the “TOTDIS” and “TOTENA” said three times as the respective commands are performed on each node.
