Thread closed: Debian 12 Kernel 6.1.0-{29,30} Audio Stutter Fix - Call for Testing
I would like to clarify what exactly we should be doing now for testing kernels newer than -28
BOTH threads on the topic have been closed.
And reference:
Closed with "This is clearly not the fix. Locking this thread; no more testing needed."
Pretty much forcing me to start a new one here rather than continuing where we left off.
I am now unclear what we should be doing to test or do after rolling back to -28 with the previous fix.
And what/how where we should be testing on newer kernels.
And where it should be discussed.
Thanks.
-SteveG
At the moment, nothing. The only current viable solution is to fix the kernel at -28. The devs are discussing a path forward.
Thanks, and please keep me in mind if you’d like any testing done on my end.
I’m very interested as you have probably noticed.
Take care and have a pleasant weekend.
A fix has been identified. Put the following in the file /etc/modprobe.d/asl3-snd-usb-audio.conf:
options snd_usb_audio lowlatency=0
Then reboot your system. This is being tested and packaged for a release today.
Man!
How did that get figured out?
Also of curious if we lost “any low latency” benefit that we had before this?
Read this post : Summary of Kernel Issues with USB Audio
