The bubble map doesn't load anymore
The bubble map doesn't load anymore. I almost always get "504 Gateway Time-out" when trying to connect anywhere on the East Coast Reflector (27339, 45225, 45192).
Is there a way to get it to load?
The stats server looks to be working but does appear to be having issues with creating the maps for the ECR nodes. I took a quick look at the server logs and it's possible that there's an issue with bad/unexpected data. This could also be a case where the map generation is just taking too long (we do have a timeout in place to protect the entire system from becoming deadlocked). I've reached out to another one of our developers who is more familiar with the backend.
We extended the map generation timeout. The bubble maps for the main ECR nodes (and those connected) are now being created ... but please be patient and avoid refreshing your browser window.
Thank you and that worked for a while. As we continue to grow, it times out more than it loads (understandable). It's a useful tool when someone connects a ton of things and starts looping systems. I know you keep a timeout to protect your system. Would it be possible to have a link to the bubble chart with a long time-out for a couple of the ECR control operators?
Our hubs are 27339, 45225, and 45192.
Thank you.
There is no "special" link that exists today for any particular user or node. It's not just network size, it's also the sheer volume of traffic hitting the server. And, unfortunately, the current architecture doesn't scale out to accommodate the ASL growth we've had.
We're in the process of replacing the current bubble chart system entirely. The new system will provide the data back to the browser and each browser will render it. This is in lieu of the server-side image rendering that happens today which is why the system times out.
