Testing request: app_rpt 0.181 and chan_irlp 0.26
New versions of app_rpt.c and chan_irlp.c are available from svn:
app_rpt.c Version 0.181
chan_irlp.c Version 0.26
1. Better control of IRLP connect and disconnect messages through config
file options and DTMF commands, and added irlpplay CLI command
to assist in queuing the messages one at a time.
Attempt to resolve Mantis bug 0000003.
New rpt.conf keywords for node stanza:
irlpann={0,1} (0 = no irlp disconnect/connect massages, 1 = play irlp
disonnect/connect messages)
See source file for DTMF command usage.
2. Better control of Echolink connect and disconnect messages through
config file options and DTMF commands
Attempt to resolve Mantis bug 0000002.
eannmode=(1,2,3} (1 = say node number only , 2 = say callsign only, 3 =
say node and callsign)
3. Added feature to call an external program on connect and disconnect.
connpgm=yourconnectprogram
discpgm=yourdisconnectprogram
Passes node which is processing the connect or disconnect as the first
arg (us), and node which is being connected or disconnected as the
second arg (them),
Attempt to add Mantis feature request 0000007.
4. Convert morse code sender to use ast_playtones_start so that the
timing of the morse code characters is consistent.
Attempt to resolve Mantis bug 0000005.
Steve
WA6ZFT
Installed both app_rpt and chan_irlp updates on my LL install. See comments below.
I assume that this is used in the IRLP/AST node stanza of rpt.conf. This version of chan_irlp seems to have broken my setup. Unable to connect to other IRLP nodes. Going back to 0.25.
Not using chan_echolink.
second arg (them),
I assume that these are used in within the IRLP/AST stanza in rpt.conf and can be used in a similar manner as the custom_on and custom_off IRLP scripts. Have not tried doing anything with them yet.
Morse is sounding good. Nice regular dots and dashes.
-- This message was NOT sent by an iPhone or Blackberry
Randy Hammock KC6HUR
http://kc6hur.net/~rhammock/
http://irlp.kc6hur.net/
If there are no horses in heaven, then when I die, I want to go where they went.
On May 16, 2009, at 4:07 PM, Stephen Rodgers wrote:
SO far I have tested the changes to the announcements. I find that the echolink announcements are changed as intended but I see no change to the way the IRLP announcements work.
I still get the Male IRLP announcer first and then the female Asterisk announcement.
I tried using the command line:
rpt cmd 2250 cop 40 2250
and
rpt cmd 2250 cop 41 2250
neither one had any effect on IRLP announcements. So I tried assigning a DTMF code to the cop commands and this didnt work for me either.
I have a question: What are the Foreign Link Local Output Path statements for?
Matt
2009/5/17 Stephen Rodgers [email protected]
  1. Better control of Echolink connect and disconnect messages through
  1. Added feature to call an external program on connect and disconnect.
second arg (them),
  1. Convert morse code sender to use ast_playtones_start so that the
Steve
WA6ZFT
[email protected]
As an addition to my earlier email, I have now added the new code ( both app_rpt and chan_irlp ) to node 2250 and node 2259.
The two nodes are connected together via IAX2.
Having established an iaxRpt connection to node 2259 and listening to 2250 via RF I can hear the following results:
Node 2250 has an incoming Echolink connection - announcement on 2250 is remote echiolink node callsign - correct
Menwhile on node 2259, the echolink connection announcement is the node number.
Reverse the node numbers and the scenario is also reversed i.e. incoming Echolink call to 2259 results in the callsign announcement on 2259 and the node number on 2250.
I have invoked COP 43 on both nodes.
I hope I have explained this clearly enough!
The CW now sounds lovely by the way. Thanks for that one.
Matt
G4RKY
2009/5/17 Matt Beasant [email protected]
and
Matt
second arg (them),
Steve
WA6ZFT
[email protected]
I have tried to duplicate this problem. I set up my nodes in a similar manner, and both nodes announce the same thing,
or whatever mode I have set them to. It just works for me.
Date: Sun, 17 May 2009 15:15:17 +0100
To: [email protected]
CC: [email protected]
Subject: Re: [App_rpt-users] Testing request: app_rpt 0.181 and chan_irlp 0.26
Matt
G4RKY
and
Matt
second arg (them),
Steve
WA6ZFT
[email protected]
comments below.
config
3 =
disconnect.
second arg (them),
they went.
[email protected]
There's only a one line change between 0.25 and 0.26 having to do with
exp node management through the CLI. It's unlikely that it could have
broken the normal IRLP connectivity. Suggestions: Try to "light-switch"
the problem by repeatedly loading versions 0.25 and 0.26 repeatedly to
ensure it follows version 0.26. 2. If if always fails in version 0.26,
issue "rpt debug level 5" from the Asterisk CLI and then please post the
output from the Asterisk CLI, after a connect attempt.
Steve
WA6ZFT
announcement.
and
for?
Matt
second arg (them),
Steve
WA6ZFT
[email protected]
This will be fixed in chan_irlp.c version 0.27 which should show up in
SVN shortly...
The foreign link stuff needs to be documented by Jim Dixon, as I don't
have a complete picture in my mind of how it all works. I'll ask him to
pull down the latest svn of usbradio/rpt.conf, and add the documentation
into it.
Steve
WA6ZFT
Steve
WA6ZFT
2009/5/17 Stephen Rodgers <[email protected]>
