Switching from simpleusb to radiousb
Hello, Me again.
I have an issue when I try to use radiousb.
I am presently using simpleusb, no issues (other than the asl menu not working)
when I try to use radiousb, i get no sound.
I am using asl on a dell 3040.
When I do the switchover settings in rpt and modules.conf then restart asterisk, the sound goes away. I cannot get into the radiousb_tune_menu either (is this the proper term?)
I am using a cm108 fob. when I switch back to simpleusb I get my sound back.
Thanks Mike
Check the device string numbers in usbradio_tune_usb_xxxxxx.conf
and see if it is a match for what you see from lsusb for your device
lsusb
repeater@n3idsdell:~$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 0d8c:0012 C-Media Electronics, Inc.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
simpleusb
[usb_592991]
; name=usb_592991
; devicenum=1
devstr=1-3:1.0
rxmixerset=280
txmixaset=352
txmixbset=352
usbradio
[usb_592991]
; name=usb_592991
; devicenum=1
devstr=1-3:1.0
rxmixerset=500
txmixaset=500
txmixbset=500
rxvoiceadj=0.500000
rxctcssadj=0.500000
txctcssadj=200
rxsquelchadj=100
fever=0
devstr=1-2:1.0
Make adjustments to your file.
what does that setting do?
I was experimenting and changing the device number didn’t seem to do anything.
do I need to reset the whole node and not just asterisk?
power off reboot, didn’t make any apparent change.
Tells the software where on the usb headers the device is physically located.
Since you can have more than one node with same looking device, you need the exact device.
If you move it, it will change.
Run lsusb again to verify.
Restart asterisk or reboot.
ok, if I understand this correctly then, if I configure as devstr= 1-2:1.0 and it works, then (without moving the device) try 1-3:1.0 it shouldn’t?
but I still get audio. I’m scratching my head on that one
Mike
did you restart asterisk ? if not you are still using the old entry.
