I keep getting a ‘too many requests. Please try again later’ when trying to log into supermon-ng. I was logged into it fine last night. I have restarted everything, Asterisk and the Pi and no luck. I have even closed out any previous instance of it where it was open. Thoughts?
That is a systemic issue. That’s just the server say it’s needs to breathe a bit. There’s nothing wrong with your configuration that would cause that message to appear in your browser.
Ensure the database restarted correctly. This is number one failure for users.
Thank you, you have found a bug. I have fixed it and will roll an updated release this afternoon around 17:00 CDT. It will be named same as current tarball. You can use sudo ./scripts/update.sh –force` to install it to fix the problem
