So i have one node on a cloud server and another radioless on a pi4 on my home network. The supermon page is running on the cloud server under node 615122. It shows as a private node and says " Node not in the astdb-update the database"
The node 612120 on my home network on a pi4 says “Could not connect to Asterisk Manager”
What version of Supermon are your running 7.4? I would look at crontab -e and see if it running the astdb.php. I would change it to run more often if its there. You can always run the database manually
“Could not connect” messages are usually password issues. You have it correct on 122, probably not the manager.conf file. Check the allmon. ini file for passwords for both nodes listed…
Yes that version and yes i have that in the crontab -e but on the one thats working but shows are a private node…the other is Hamvoip on a Raspberry pie. Not sure if i cant reply to the 2nd person too but i have all the passwords the same. The 120 is on Hamvoiop on a pi4 on my home network the 122 is asl on a virtual server if that matters…
