If I have asterisk and hamvoip nodes, can they be controlled by a single UI using either Allmon or Supermon? Thx. Adrian.
Yes, one instance of Allmon could support both an ASL server and a HamVoIP server.
When using Allmon to connect to a remote server be sure to secure the AMI. Permit only IP of the server that is running Allmon.
[admin]
secret = <your_secret_password>
read = all,system,call,log,verbose,command,agent,user,config
write = all,system,call,log,verbose,command,agent,user,config
deny = 0.0.0.0/0.0.0.0
permit=xxx.xxx.xxx.xxx/255.255.255.255
I assume all of the above applies to Supermon but I don’t use it.
Yes you can. I do it here. Just add the other servers in allmon.ini.php
I run a dial package and a hamvoip package on my system here.
Keith
