Supermon 7.4 install issue
I’m trying to install Supermon 7.4 on my new node running ASL3. I have one node running HamVOIP, but I wanted to try the new software. I’m following the KD5FMU’s video on installation but it’s hanging up with this line:
wget "http://2577.asnode.org:43856/supermonASL_fresh_install"-O supermonASL_fresh_install
When I run that command I get the following:
I have admin access to the node. I have read some of the comments and some have gotten this to work, but I seem to be missing something.
You have a missing space, should be
sudo wget "http://2577.asnode.org:43856/supermonASL_fresh_install" -O supermonASL_fresh_install
-O is short for –output and tells wget to save what it fetches as a file named whatever comes after it, in your case supermonASL_fresh_install
Now I’m getting permission denied.
You still need sudo.. I only highlighted the part with the missing space.
I used the [script from this repository]( GitHub - hardenedpenguin/ASL3_Multi_App_Install: This is a script file that will help install AllScan, DvSwitch Server, Supermon 7.4, Basic Calculator, and Plocate ) to install Supermon 7.4+ just yesterday on my ASL3 node and it worked without issue.
Cool, is nice to see the heavily modified script I gave Freddy is helping people.
It’s spelled Freddie, just FYI
Blame autocorrect brother :face_with_tongue:
Anyone able to download the script at http://2577.asnode.org:43856/supermonASL_fresh_install ?
Supermon support would be @ Supermon@groups.io | Home
Also, it should be noted that asnode.org is NOT an AllStarLink service and has been down for several days according to various online sources. However, ASL always recommends using the official DNS name service of ${NODE}.nodes.allstarlink.org.
