Statpost error 429
On my hub server running Debian 12 and ASL2, I'm getting error 429 on statpost reguests. Error 429 usually indicates "too many requests". 'Haven't seen this previously.
Tom / K5TRA
If I comment out the statpost request for each node; then they will not be seen on the bubble map, correct ?
Just leave it as-is and ignore the 429 warnings. They are temporary until we evolve further.
OK, thanks for the reply. 'Any guess when the next step in evolution will happen?
Few weeks-ish or so.
Any updates on this issue? I’ve been unable to connect to any nodes for a couple of days now. When I try, I get the following error messages:
shari*CLI> rpt fun 27929 *343015
-- Call accepted by 207.246.82.94:4569 (format ulaw)
-- Format for call is (ulaw)
-- Hungup 'IAX2/207.246.82.94:4569-8221'
-- Hungup 'DAHDI/pseudo-2052911525'
[2025-12-30 20:21:26.998] WARNING[7324]: app_rpt.c:1043 perform_statpost: statpost to URL 'http://stats.allstarlink.org/uhandler?node=27929&time=1767144086&seqno=1159&nodes=C43015&apprptvers=3.6.3&apprptuptime=34115&totalkerchunks=6&totalkeyups=11&totaltxtime=92&timeouts=0&totalexecdcommands=7&keyed=0&keytime=28712' failed with code 429 : Request too soon
-- Hungup 'DAHDI/pseudo-1937046116'
-- <DAHDI/pseudo-839867786> Playing 'rpt/node.gsm' (language 'en')
-- <DAHDI/pseudo-839867786> Playing 'digits/4.ulaw' (language 'en')
-- <DAHDI/pseudo-839867786> Playing 'digits/3.ulaw' (language 'en')
-- <DAHDI/pseudo-839867786> Playing 'digits/0.ulaw' (language 'en')
-- <DAHDI/pseudo-839867786> Playing 'digits/1.ulaw' (language 'en')
-- <DAHDI/pseudo-839867786> Playing 'digits/5.ulaw' (language 'en')
-- <DAHDI/pseudo-839867786> Playing 'rpt/connection_failed.gsm' (language 'en')
-- Hungup 'DAHDI/pseudo-839867786'
-- Hungup 'DAHDI/pseudo-1348428405'
shari*CLI>
Jim W8BS
The HTTP 429 indicates you've already posted to stats.
Any other errors are unrelated.
Chuck is correct. Stats is entirely irrelevant to registration. Registration is a core necessity, but Stats is a nice-to-have. As right now, your registration is valid. However, any chance you're on T-Mobile?
No, I use AT&T First Net.
Jim W8BS
That might have the same problem as T-Mobile. Can you test it on another service?
Another Internet Service? No, That’s all we have here.
My Pi-Star node works just fine from here to the Brandmeister network.
Up until a couple of days ago, my Shari was working fine too.
Jim W8BS
The new code for stats.allstarlink.org has been deployed. So far so good, but we're keeping an eye on things.
