Startup Macros in ASL3?
I’ve successfully gotten 2 instances of ASL3 running on 2 different standalone servers/nodes. So far so good.
Now I’m trying to get it working on my radioless Hub server, which hosts both a private node hub as well as my public node - it runs as a VM under ProxMox. Overall, it’s working fine (Supermon7+ included) but I’ve run into an issue where I cannot get the startup Macro to run under my private node stanza
I’ve been through the docs several times but I still haven’t found what I’m looking for (with apologies to U2)
Can you provide any logging output? Config snippets?
Well, I do have an update about this. It seems the *8 commands are all commented out in the new default rpt.conf. Originally, I didn’t think to check those as issuing a Permanent Connection from within Supermon worked. Anyway, uncommenting the *8 block in rpt.conf and restarting Asterisk provided the solution as my startup macro is now working.
While the developers seem to have done a great job on the code, the documentation for ASL remains, IMHO, poor
The project welcomes all contributions to the documentation via AllStarLink/ASL3-Manual.
Ken,
I know that you have mentioned before about the poor ASL documentation.
Why not volunteer your time to help make it better?
Marshall
I’d be happy to offer some help. Do I need an account?
You will need a GitHub account, yes. After that, you can use the directions found at ASL3-Manual/README.md at main · AllStarLink/ASL3-Manual · GitHub. The developers will be happy to help get you started.
Ahh OK. I have a Github account…
I’ll need your GitHub user ID.
