Startup Macro cannot handle NNX nodes
When I add a startup macro to my private numbered node, permanently linking it to my NNX numbering plan node, it fails, and when looking at asterisk, it seems to be dropping the last digit and can’t locate that node because it doesn’t exist.
root@chucktaylor:~# asl-show-version
OS Kernel : 6.1.0-40-amd64
Asterisk : 22.5.2+asl3-3.6.2-1.deb12
ASL [app_rpt] : 3.6.2
Installed ASL packages :
Package Version
asl3 3.11-1.deb12
asl3-asterisk 2:22.5.2+asl3-3.6.2-1.deb12
asl3-asterisk-config 2:22.5.2+asl3-3.6.2-1.deb12
asl3-asterisk-modules 2:22.5.2+asl3-3.6.2-1.deb12
asl3-menu 1.15-1.deb12
dahdi 1:3.1.0-2
dahdi-dkms 1:3.4.0-10.asl.deb12
dahdi-linux 1:3.4.0-10.asl.deb12
dahdi-source 1:3.4.0-10.asl.deb12
Inquiry
Is this a "new" NNX node number? If so, you may be affected by ASL3 Manual : Issues with connections to "new" NNX Nodes.
What is the node number you are trying to connect to?
So I actually had read that before posting kinda came to the determination it wouldn’t impact me since both my nodes were local to each other (same asterisk session).
Is there a preferred way to hard code these entries somewhere other than an authoritative NS locally and forwarding everything else?
Nodes on the same network have a special configuration.
