you may try this for your squelch setting…
Bring up your CLI> Screen.
If you have more that one URI or RIM, you must first select a USB device.
‘example’ CLI>radio active usb20123
Set your radio’s squelch wide open for the next commands
radio tune rxsquelch
'you’ll get the Current Signal Strength is <some number like 695>
now set the squelch setting between 100 to 150 points higher than the Current Signal Strength 795 to 845
radio tune rxsquelch 795
set you radio squelch on and check your results. next you save it
radio tune save
I’m sure there is more suggestions out there including the rxsquelchdelay=80 ; delay in ms carrier squelch tail eliminator in the usbradio.conf
I’ve gotten it to work with carrierfrom=dsp and ctcssfrom=dsp but it seems others report it only to work with the rxdemod= set to flat.
It may have to update ACID. More on that can be found in the archives.
To: app_rpt-users@ohnosec.org
Sent: Sunday, October 6, 2013 10:48 PM
Subject: [App_rpt-users] Squelch Burst
Spifically, when I use COR from the radio, I have a squelch crash when a user unkeys. If I use squelch=dsp, then the crash is not there. But, the squelch action of the node receiver is not the best. I would really like to use COR but dislike the squelch burst. Is there a way to delay the audio and shut it off before the squelch closes? Like in a audio delay board for a repeater controller?
Thanks for info that you could pass along.
Jim W7RY
