Restarting ASL did not correct it but restarting the VM did. Not exactly sure how "thorough" a restart of asterisk is however.
Attached is the asterisk log before the reboot
messages.log.txt (98.6 KB)
You appear to be the only person having this issue now. What version of asl3-asterisk do you have installed?
As per the linked thread, I installed the development build as per your suggestion (on the date I posted I had done so).
I do notice there continues to be a memory leak. Attached is a screenshot of CPU and memory usage right before I rebooted:
CPU usage is typically around 2% to 5 % and memory usage is easily under 300 megs
And is that being consumed by the asterisk process? Just looking at the overall system graph isn't informative enough for troubleshooting.
My bad, I grabbed the wrong Summary before the reboot. When it fails again, I will be more careful and grab the VM's screenshot
