Hi everyone.
Since i would like to use my node to connect a voip telephone, i bought a snom 710 for some euros and now…i am not able to do nothing or, better, i don t how to configure it.
First of all i followed the instruction in wiki referred to allstar3 adding the info in the configuration.
If i get in snom 3 config i find:
Login, username ( i don’t understand the difference). Then, do i have to selcet asterisks as server?
For the server, i use my local ip of my node, but even if i put at the end :5060 it doesn’t work. I tried to open 5060 on my router but it says it has already on use (do you suggest to nat 5060, for example from 5550 to 5060? Or change 5060 in configuration, but i don’t know where)?
I know these are a lot of questions…
