SkywarnPlus with Debian 13 Trixie
The normal installation of SkywarnPlus does NOT work with Debian 13 due to an error with pydub. The error is from Python 3.13. My thanks to N6LKA for providing a workaround. Install Python 3.11 alongside Python 3.13, and configure SkywarnPlus to use it. I found I also had to install ffmpeg.
PythonErrors.
Here is the steps I used:
1] Install build dependencies:
sudo apt install build-essential libssl-dev zlib1g-dev libncurses5-dev libncursesw5-dev libreadline-dev libsqlite3-dev libgdbm-dev libdb5.3-dev libbz2-dev libexpat1-dev liblzma-dev tk-dev libffi-dev
2] Download and compile Python 3.11: ( 7 steps )
cd /tmp
wget https://www.python.org/ftp/python/3.11.10/Python-3.11.10.tgz
tar xzf Python-3.11.10.tgz
cd Python-3.11.10
./configure --enable-optimizations --prefix=/usr/local
make -j$(nproc)
sudo make altinstall
3] Modify SkywarnPlus shebang:
sudo nano /usr/local/bin/SkywarnPlus/SkywarnPlus.py
Change first line from #!/usr/bin/python3 to #!/usr/local/bin/python3.11
4] Install Python dependencies for Python 3.11:
sudo /usr/local/bin/python3.11 -m pip install requests pydub python-dateutil pytz ruamel.yaml
5] install ffmpeg
sudo apt update
sudo apt install ffmpeg x264 x265
6] Fix permissions for asterisk user:
sudo mkdir -p /tmp/SkywarnPlus
sudo chown asterisk:asterisk /tmp/SkywarnPlus
You went threw an awful lot of work. You could simply have used the following patch and stayed using python3.13 without polutting the system.
https://raw.githubusercontent.com/KD5FMU/ASL3_Multi_App_Install/refs/heads/main/swp-install-trixie.patch
