SkywarnPlus no audio to YSF reflector
I have a Allstar node (Hamviop) that runs Ham Shack Hotline RF Bridge and I added SKYwarnPlus. SkywarnPlus appears to be running correctly but, no audio is being sent to the YSF Reflector. I’ve tried everything I could think of with no success to get the audio to YSF, any and all ideas are welcome!
This doesn’t really have anything to do with SkywarnPlus at all. SkywarnPlus sends telemetry audio to app_rpt, which only plays telemetry audio on the LOCAL node/interface (whatever rxchannel is set to in rpt.conf ). This is just how app_rpt is designed. I’m not familiar with bridging app_rpt to YSF or HH, but I suspect this is the issue.
I just had to fix the script file for a friend’s ASL computer, the one that gives current wx info. The weather service changed server name/address. Instead of w1.weather.gov it is now forecast.weather.gov. This might be your issue… GeorgeC W2DB
OP is not having an issue with WX info or data sources, as stated:
Posting this here for reference -
I would kinda imagine that your RF Bridge is not allowing that.
By default, amateurs should not be broadcasting repeater voice (allison), CT’s and other telemetry to those digital networks and most default settings are to appease that.
But I can not speak to your bridge or skywarnplus.
Just a path to check. There may not be anything wrong except your assumption…
I really need to get my eyes checked
