Just run the installer it installs the repo and launches install then run setup.
sudo bash setup.sh
This is designed for users who don't want to edit anything.
Read the blog post for more info. And report any problems.
Designed to just work and be upgradable through the apt-get updates.
Made in Louisiana...........
You should have fun and not worry about setting things up.
Just WOW! I really appreciate the work you all are doing to overhaul our ecosystem. It will be truly amazing to have Skywarn and all spotters like me able to connect and share data. Then we really will have a Ham radio system that NOAA and all the civil warning networks will sit up and take us seriously for front line response to weather energencies. Kudos and 73 fellas! Craig @ EN52xk with KD9UQE.
SKYWARN® is a registered trademark of the National Weather Service. There is no software called "Skywarn".
If you are going to pass this off as something you wrote from scratch, then I would recommend cleaning the AI prompts you used to generate this out of your README.md.
I get that you are trying to put out something useful, you really need to review the actual code AI has spit out for gps, you have many undeclared globals that are never even set or used for that matter.
I have tried to tell you to review the code, it is a mess and full of bugs and security issues. You seem to have ignored my suggestion. I went ahead and documented it all for you ....
Please address the issues so you are not compromising users.
