SIP
Is there a way to connect
a SIP phone/cl ient (in bound calls) to
my Allstar node to be able to talk on
the Allstar node? I got Zoiper to w ork OK on my smartphone, but it’s IAX. I
couldn’t find much online about setting up the conf files
fir SIP.
                              Thanks, Greg
KD3SU
I use this in my sip.conf for the Polycom phone that I have here.
[polycom]
type=friend
context=radio-control
secret=yoursupersecretPW
host=dynamic
dtmfmode=rfc2833
username=polycom
disallow=all
allow=ulaw
progressinband=yes
transfer=no
Mark, could you say a bit about how it is used?
Bob
k6ecm
[polycom]
type=friend
host=dynamic
dtmfmode=rfc2833
username=polycom
disallow=all
allow=ulaw
progressinband=yes
transfer=no
If you have a sip phone or Application, you can connect to the node with a phone to command it, and connect to other nodes just like a radio - except it can use vox or dtmf to key the xmtr depending on how it is configured.
example using vox:
extensions.conf:
[radio-control]
exten=1001,1,Answer
exten=1001,n,Playback,rpt/node
exten=1001,n,Rpt,1001|Pv
If you want to access it from outside your home network, need to have port 5060 forwarded to your allstar box - unless you change that in sip.conf… then fwd to whatever other port is used, one big downside to opening sip, is there tend to be a lot of ‘people’ from other countries who try to hack/use your sip to place calls etc… so one has to be careful with opening that service to the world, iax is not as common… it is a bit safer to have 4569 open for iax - I only use the SIP internally so I don’t have that issue, and use iax for other devices -
Hope that helps…
Bob
k6ecm
Sent from iPad
[polycom]
type=friend
host=dynamic
dtmfmode=rfc2833
username=polycom
disallow=all
allow=ulaw
progressinband=yes
transfer=no
“Got Root?”
How many software engineers does it take to change a light bulb?
None. It’s a hardware problem.
Unix is user friendly. It’s just very particular about who it’s friends are.
WINDOWS: Will Install Needless Data On Whole System
MICROSOFT: Most Intelligent Customers Realize Our Software Only Fools Teenagers.
A ntennas
P oorly
P laced
L acks
E ngineering
The best way to accelerate a computer running Windows is at 9.81 m/s².
“I get paid to support Windows, I use Linux to get work done.”
I’m not having much luck. It won’t register. I tried inside the router and 2 different Allstar nodes and 3 different applications. I tried Sipdroid , SFLphone on Linux
and I’m
working on an A ndriod
App using the SIP libs. There’s a walkietalkie example
I’m trying to add to an Allstar control
app I’m writing. I’ll double c heck
my settings again. This is on a BBB and Pi3.
        IAX works fine.
        tnx, 73 Greg KD3SU
On 06/04/2016 12:00 AM, Mark Johnston
example using vox:
extensions.conf:
[radio-control]
exten=1001,1,Answer
devices -
Hope that helps…
“Got Root?”
              How
bulb?
** None.
It’s a hardware problem.**
            Unix
it’s friends are.
                MICROSOFT: Most
Fools Teenagers.
            A
ntennas
            P oorly
            P laced
            L acks
            E ngineering
at 9.81 m/s².
**** “I
get work done.”****
kk6ecm@gmail.com
Bob
k6ecm
Sent from iPad
                On Jun 3, 2016, at 8:35 PM, Mark Johnston <                    >
[polycom]
type=friend
host=dynamic
dtmfmode=rfc2833
username=polycom
disallow=all
allow=ulaw
progressinband=yes
transfer=no
              To unsubscribe from this list please visit [](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)
                                  You do not need a password to unsubscribe, you
can do it via email confirmation. If you have
trouble unsubscribing, please send a message to the
list detailing the problem.
Not sure if you checked this yet but depending on your version of Allstar, sip is not enabled by default. Check modules.conf for noload sip and comment it out.
This is how I set my sip phone up.
http://www.w2ymm.com/myallstarlink.html#sip_phone
Bob w2ymm
Bob Prybyzerski
631-960-1051
W2YMM
example using vox:
extensions.conf:
[radio-control]
exten=1001,1,Answer
devices -
Hope that helps…
“Got Root?”
              How
bulb?
** None.
            Unix
it’s friends are.
                MICROSOFT: Most
Fools Teenagers.
            A
ntennas
            P oorly
            P laced
            L acks
            E ngineering
at 9.81 m/s².
**** “I
get work done.”****
kk6ecm@gmail.com
Bob
k6ecm
Sent from iPad
[polycom]
type=friend
host=dynamic
dtmfmode=rfc2833
username=polycom
disallow=all
allow=ulaw
progressinband=yes
transfer=no
That was it!
  I have a Linksys ATA      ,
could I se t it up to
connect also?
  Thanks, 73, Greg
On 06/04/2016 10:47 AM, Bob Prybyzerski
Bob w2ymm
    Sent from my iPhone
Bob Prybyzerski
631-960-1051
W2YMM
    On Jun 4, 2016, at 10:19 AM, Greg Thornwall <        >
wrote:
        I'm not having much luck. It won't register. I tried inside
the router and 2 different Allstar nodes a nd 3 different
applications. I tried Sipdroid, SFLphone on Linux and I’m working
on an Andriod App using the SIP libs .
example I’m trying to add
to an Allstar control app I’m
writing. I’ll double check my settings again. Thi s is on a BBB
and Pi3.
        IAX works fine.
        tnx, 73 Greg KD3SU
                  You do not need a password to unsubscribe, you can do it
via email confirmation. If you have trouble unsubscribing,
thorn@myactv.net
configured.
example using vox:
extensions.conf:
[radio-control]
exten=1001,1,Answer
other devices -
Hope that helps…
“Got Root?”
                    How
light bulb?
None.
                  Unix
                      MICROSOFT: Most
                  A
ntennas
                  P oorly
                  P laced
                  L acks
                  E ngineering
**** “I get paid to support
done.”****
Bob
k6ecm
Sent from iPad
                      On Jun 3, 2016, at 8:35 PM, Mark Johnston <>
[polycom]
type=friend
host=dynamic
dtmfmode=rfc2833
username=polycom
disallow=all
allow=ulaw
progressinband=yes
transfer=no
you can do it via email confirmation. If you
have trouble unsubscribing, please send a
That I am not familiar with. I stumbled into getting mine working and haven’t tried to go much further.
Bob Prybyzerski
631-960-1051
W2YMM
Bob w2ymm
    Sent from my iPhone
Bob Prybyzerski
631-960-1051
W2YMM
and Pi3.
        IAX works fine.
        tnx, 73 Greg KD3SU
thorn@myactv.net
configured.
example using vox:
extensions.conf:
[radio-control]
exten=1001,1,Answer
other devices -
Hope that helps…
“Got Root?”
                    How
light bulb?
None.
                  Unix
                      MICROSOFT: Most
                  A
ntennas
                  P oorly
                  P laced
                  L acks
                  E ngineering
done.”****
Bob
k6ecm
Sent from iPad
[polycom]
type=friend
host=dynamic
dtmfmode=rfc2833
username=polycom
disallow=all
allow=ulaw
progressinband=yes
transfer=no
