I plan on rebuilding all my nodes on new ASL 3 installs. My question for the hive mind, do you think I can just take the level values from my old ASL2 install and use them on ASL3 (the level values not the files as I understand there is a new syntax) or do I need to get the service monitor out and re-tune everything?
I would imagine the levels should be the same. Thoughts?
