Hello I am in the process of switching all of our repeaters from HamVoip to ASL3.
However even with the RXBoost Disabled the rx audio is now coming in way to hot.
I have turned it down to 10 and it is still too loud I have found a work around as we use mostly mtr2000s through the stations alignment to back it off, but is there another way to shave some input volume off not all of our repeaters have such an easy adjustment?
Thanks in advance.
I use usbradio; hence, you can ‘reduce the vol’ by adjusting rxvoiceadj. Here’s an snip of my usbradio.conf. REMEMBER that the settings for audio came from radio-tune-menu.
