SimpleUSB gpio?
I’m trying to manipulate a GPIO pin off of a URIx and I am not able to get it to work for whatever reason. If I send a cop,62 command to toggle it, it does not change the state.
I found this message from Jim that was posted in June 2011:
http://ohnosec.org/pipermail/app_rpt-users/2011-June/002725.html
Does anyone know if this was ever implemented? This was quite some time ago.
I might be able to use usbradio instead for my application, but prefer SimpleUSB as it’s easier to implement.
Stephen
K1LNX
An update on this, and I’ve learned something that was not so obvious to me, so I’ll put this out there in case someone runs into this in the future.
Consider my dilemma… I am using an RTCM to drive a pair of radios in full duplex mode. I needed to drive a relay (or MOSFET board in my case, more on that in a bit) to turn a fan on the transmit radio on and off as needed. Considering there are no GPIO’s on the RTCM, I had a URIx also connected that I planned on using for another application that I thought I could tap the GPIO off of. I found Kyle, K0KN’s excellent fan script, as well as this resource:
http://latinovoip.net/allstar-and-the-gpio-fan-script-for-dmk-engineering-uri/
I elected to use the version linked above, and got everything configured, but discovered my cop,62 commands were not working to toggle the GPIO line on the URI. I tried a variety of differing configs and troubleshooting methods, none of which worked, when I finally tried to issue the cop command from the node that is on the URI instead as a test, and what do you know, it worked.
It also appears that GPIO support was added into chan_simpleusb as of revision 1060:
http://svn.ohnosec.org/viewvc/projects/allstar/astsrc-1.4.23-pre/trunk/asterisk/channels/chan_simpleusb.c?revision=1060&root=svn&view=markup
On the hardware side, I had issues with the relay board I was using. I was seeing approximately 3.25 v when the GPIO was toggled to an on state on the URI. That was not enough to “trigger” the relay board to fire the relay, it needs right at a solid 5 volts. Rather than add another piece of hardware to ramp the voltage up, I ran across this on Ebay:
http://www.ebay.com/itm/301357646243?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
This is a 3 channel MOSFET board that will switch the output on above 2.5v, off at ground. Perfect for my application. I have yet to test it, but have high confidence it will work just fine for my intended purpose.
On the software side, I had to make a few small changes in the scripts that I got from the link above, most notably:
run_app_rpt_fan.sh
/etc/asterisk/local/app_rpt_fan.sh 1999 > /dev/null & ; change 1999 to the node number that is attached to the URI, a private node in my case
app_rpt_fan.sh
PTTSTATE=“/tmp/RPT_TXKEYED1999” ; change from the $1 variable to the node number that is attached to the RTCM instead
There are more likely easier solutions than what I’ve provided above, but this does work as intended now. After 10 seconds, GPIO1 goes high, goes back to ground after 10 minutes. An even easier solution would be to probably just use a snapdisc and have it fire on a certain temperature, but I wanted more granular control so that wasn’t really an option. I could have also elected to use a Raspberry Pi and tap one of the GPIO’s there instead, but my AllStar server is built on an x86 box running other applications so that wasn’t really an option either.
I’d like to explore the possibility of maybe having chan_voter talk to the GPIO’s in chan_usb or simpleusb. We could say add a config to the voter.conf file for the particulars for example. Not sure what this would take, but curious if it could be done?
Hope this helps someone in the future…
Stephen
K1LNX
Stephen
K1LNX
Sorry,
I do have to ask the obvious,
Are you sure you are testing the output correctly ?
I believe these FLOAT and switch to ground when active.
Just like a parallel port.Don't use them so I don't know for sure.
So you need to check continuity between ground and the pin in question for activity.
...mike/kb8jnm
I'm trying to manipulate a GPIO pin off of a URIx and I am not able to get
ohnosec.org - ohnosec Resources and Information.
ago.
SimpleUSB as it's easier to implement.
Stephen
K1LNX
http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users and scroll down to the
bottom of the page. Enter your email address and press the "Unsubscribe or edit
options button"
problem.
Hi Mike… yes, I was testing between ground and the GPIO pin question (GPIO1 in my case) for voltage.
See my later message I posted for details on what I found.
Stephen
K1LNX
On Thu, Aug 4, 2016 at 9:05 AM, mike@midnighteng.com wrote:
Sorry,
Just like a parallel port.Don’t use them so I don’t know for sure.
…mike/kb8jnm
ago.
Stephen
K1LNX
options button"
problem.
Hi Stephen,
While the CM108/CM119 audio chips found in URI's are powered from the +5V
USB source, they contain an internal +3.3V regulator and are internally
completely 3.3V logic....So, you'll never see more than +3.3V as a
logic "high" level coming from the GPIO pins.
73, David KB4FXC
On Thu, 4 Aug 2016, Stephen - K1LNX wrote:
An update on this, and I've learned something that was not so obvious to
me, so I'll put this out there in case someone runs into this in the future.
Consider my dilemma.. I am using an RTCM to drive a pair of radios in full
Considering there are no GPIO's on the RTCM, I had a URIx also connected
the GPIO off of. I found Kyle, K0KN's excellent fan script, as well as this
resource:
know, it worked.
revision 1060:
URI. That was not enough to "trigger" the relay board to fire the relay, it
run_app_rpt_fan.sh
app_rpt_fan.sh
PTTSTATE="/tmp/RPT_TXKEYED1999" ; change from the $1 variable to the node
There are more likely easier solutions than what I've provided above, but
I wanted more granular control so that wasn't really an option. I could
have also elected to use a Raspberry Pi and tap one of the GPIO's there
applications so that wasn't really an option either.
I'd like to explore the possibility of maybe having chan_voter talk to the
GPIO's in chan_usb or simpleusb. We could say add a config to the
Hope this helps someone in the future...
Stephen
K1LNX
> ago.
> 73
> Stephen
> K1LNX
Ahh ok… thanks David, and that makes sense so I appreciate the clarification :slight_smile:
On Thu, Aug 4, 2016 at 9:19 AM, David McGough kb4fxc@inttek.net wrote:
Hi Stephen,
While the CM108/CM119 audio chips found in URI’s are powered from the +5V
completely 3.3V logic…So, you’ll never see more than +3.3V as a
logic “high” level coming from the GPIO pins.
73, David KB4FXC
resource:
know, it worked.
revision 1060:
run_app_rpt_fan.sh
app_rpt_fan.sh
Stephen
K1LNX
ago.
Stephen
K1LNX
Hello All,
  In my usual fashion, I exited the firsttime script for setting up a DIAL system.
I have found the scripts in
/usr/local/sbin
  I see that their are several files listed :
firstime (( Seems to be 0 KB File )
firsttime
netsetup
nodesetup
I have tried to execute the script file firsttime by
. firsttime
but seems to do nothing. Could it have something to do
with the line in that script:
if [ -e /etc/asterisk/firsttime ]
73 de Angelo
do the following:
touch /etc/asterisk/firsttime
/usr/local/sbin/firsttime
73, Steve N4IRS
On 8/5/2016 11:43 AM, Angelo wrote:
Hello All,
/usr/local/sbin
firsttime
netsetup
nodesetup
. firsttime
73 de Angelo
"Anything is possible if you don't know what you are talking about."
1st Law of Logic
This is now covered in the FAQ. Please refresh:
http://docs.allstarlink.org/drupal/node/170
Kevin - W3KKC
Volunteer documentation support staff.
On 8/5/2016 11:51 AM, Steve Zingman wrote:
do the following:
73, Steve N4IRS
Hello All,
/usr/local/sbin
firsttime
netsetup
nodesetup
. firsttime
73 de Angelo
