simple udp interface
Look at the usrp channel driver
Sent via smoke signal (AT&T 4G LTE)
-------- Original message --------
Date: 04/29/2016 5:55 PM (GMT-05:00)
To: app_rpt-users@ohnosec.org
Subject: [App_rpt-users] simple udp interface
Is there a simple way to connect to asterisk/allstar via a udp socket ? I have a source of network audio that can source and receive raw PCM, 64K, 8 bit. I’ve looked at the rtpdir and outbound-only RTSP drivers but can’t quite figure out how they really work, at least not quickly, and I was hoping someone already has this … it needs to support COS and PTT signaling as well of course …
Sent from an iPhone 6
what is the format of the data ? is there a header or something to indicate PTT or does it just use the fact data is coming in and timeout after it stops. Is there a way to set what codec is used in the channel ? thanks
PCM, yes, no.
Here is a link to the source to the channel driver, should answer
all your questions.
73, Steve N4IRS
http://svn.ohnosec.org/viewvc/projects/allstar/astsrc-1.4.23-pre/trunk/asterisk/channels/chan_usrp.c?revision=1442&root=svn&sortby=file&view=markup
  On 04/29/2016 06:43 PM, David Krauss
and timeout after it stops. �Is there a way to set what codec is
used in the channel ? �thanks�
    On Apr 29, 2016, at 5:57 PM, Steve Zingman <>
          Sent via smoke
receive raw PCM, 64K, 8 bit. I’ve looked at the rtpdir and�
really work, at least not quickly,� and I was hoping someone
as well of course …
      To unsubscribe from this list please visit and scroll down to the bottom of the page. Enter your email
email confirmation. If you have trouble unsubscribing, please
send a message to the list detailing the problem.
1st Law of Logic
