Novice here. Has anyone used a SignaLink USB for the interface between the radio and the computer? If you did, what did you have to do? 2020-04-05T04:00:00Z
The SignalLink hardware is not supported by ASL software. You need to find a usb sound fob that has specific chip set in it.
CM108
CM119A
CM119B
There are several vendors that make compatible usb sound radio interfaces for Allstarlink.
The URI-http://www.dmkeng.com/Products.htm
Or
Masters Communications- http://www.masterscommunications.com/
Or you can build your own.
https://allstarsetup.com/modify-a-cm108-sound-fob/
Marshall-ke6pcv
Sent from my iPhone
On Apr 5, 2020, at 8:32 AM, JD Delancy via AllStarLink Discussion Groups noreply@community.allstarlink.org wrote:
April 5Novice here. Has anyone used a SignaLink USB for the interface between the radio and the computer? If you did, what did you have to do? 2020-04-05T04:00:00Z UTC
Tnx Marshall
a friend told me that he uses the URI
(universal radio interface). Is this one good and where does one
find it? What’s the Allstar preferred?
jd
On 4/5/20 12:37 PM, Marshall Oldham via
AllStarLink Discussion Groups wrote:
KE6PCV ASL AdminApril 5 The SignalLink hardwareis not supported by ASL software. You need to find a usb
CM108
CM119A
CM119B
There are severalvendors that make compatible usb sound radio interfaces
for Allstarlink.
Or
Or you can build yourown.
Marshall-ke6pcv
Visit Topic
In Reply To
April 5 Novice here. Has anyone used aSignaLink USB for the interface between the radio and the
2020-04-05T04:00:00Z (UTC)
Visit
You are receiving this because you enabled mailing listmode.
Both the URI and the Master Communications are good units.
You can find both of these at that following websites.
http://www.dmkeng.com/URI_Order_Page.htm
http://www.masterscommunications.com/products/radio-adapter/ra42.html
Marshall - ke6pcv
From: JD Delancy via AllStarLink Discussion Groups [mailto:noreply@community.allstarlink.org]
Sent: Sunday, April 05, 2020 10:02 AM
To: ke6pcv@cal-net.org
Subject: [AllStarLink Discussion Groups] [App_rpt-users] SignaLink USB Interface
J_D
April 5
Tnx Marshall
jd
In Reply To
KE6PCV ASL Admin
April 5
The SignalLink hardware is not supported by ASL software. You need to find a usb sound fob that has specific chip set in it. CM108 CM119A CM119B There are several vendors that make compatible usb sound radio interfaces for Allstarlink. The URI-http://www.dmkeng.com/Products.htm Or Masters Com…
Previous Replies
KE6PCV ASL Admin
April 5
CM108
CM119A
CM119B
Or
Marshall-ke6pcv
J_D
April 5
I’ve had good luck with these. $50 Plus $5 Shipping, comes with the USB cable and a DE-9 connector. http://www.repeater-builder.com/products/usb-rim-lite.html
I ordered 2 of these, and I think the shipping was still only $5. I just setup a simple VHF and a UHF node. Both of the radios had 6 pin mini din jacks on them. https://www.amazon.com/Monoprice-6-Feet-MDIN-6-Cable-100092/dp/B001TKQOTG/ref=sr_1_5?dchild=1&keywords=6+pin+din+cable&qid=1586180373&sr=8-5
Cut that in half and you have two radio cables for $5.
I don’t understand why ASl cannot support SignalLink? It essentially function the same as those DRA dongles.
STARTECH Mod by WA2KJC.pdf (2.2 MB)
I use the Star Tech usb sound card and modify it.
Dave
