Good Afternoon,
I have just transitioned a mobile node from HamVOIP to ASL3. It has a shutdown module that worked by adding the following: SHUTDOWN_MONITOR="enabled" in /usr/local/etc/allstar.env in HamVOIP.
I am not finding this to work the same. Is this option available in ASL3? If supported, does it need to enabled in a different way?
Thank you in advance,
Travis - K2PCB
