Shutdown and Reboot Commands using DTMF
I’m needing to put reboot and shutdown commands into my node. I’d like to carry my pi node mobile, but I don’t want to just pull power from it when i’m ready to shut it down and move it back in the house. I would like to be able to shut the pi down using DTMF. Can someone walk me through putting a reboot and a shutdown command in my node where i can shut it down using DTMF? I know that Hamvoip has commands in their nodes, but I’m at the point where I refuse to use Hamvoip. Need to do this using ASL.
app_rpt can call a script with dtmf using cmd. In the [functions] stanza, add a dtmf function like so:
xxxx = cmd, /etc/asterisk/local/shutdown.sh
Of course xxxx is a unique dtmf sequence.
Then create your script /etc/asterisk/local/shutdown.sh
#! /usr/bin/bash
/usr/sbin/shutdown -h now
This post might be helpful Command to execute external script?
