I have an echolink node which services a nearby repeater which does not have internet access.
I configure the transceiver to connect to the repeater and configure it as an echolink mode.
And this works stably.
I would like to replace this with a SHARI PIHat V.
I configure the SHARI PIHat V as an allstar node on a simplex link frequency and all is fine.
I configure the SHARI PIHat V as an echolink link node on a simplex link frequency and all is fine.
I configure the SHARI PIHat V as an echolink repeater node on a simplex link frequency and all is fine.
I configure the SHARI PIHat V as an echolink repeater node on a split frequency and it cycles back and forth between transmitting and receiving at about 3 second intervals.
Removing the split transmit/receive frequency and the problem goes away.
Thoughts? This is the critical use for this SHARI System.
Are you ‘duplex’ with a existing active repeater ?
Sounds like classic ‘PING PONG’
If you are trying to establish asl/el connection > ‘to a repeater’, you need to set allstar as a simplex/half duplex connection and your radio as a transceiver of half duplex.
For asl, I believe duplex 0
Otherwise you are getting reactivated/COS’d by each others ‘tail’
You might also need to ctcss both ends as well.
I am not familiar with the device you are using. But you can not use asl in ‘repeater mode’ unless the ‘radio device’ is a full duplex repeater. It is set for what the connected radio is, not what you are connecting to with it.
The SHARI PiHat is not a full duplex device. Do not configurre it as a repeater. Configure as a simplex node with an offset in the tx and rx frequencies.
that is called desense. hense that is why repeaters use duplexers. Echolink is 1/2 duplex mode only not like allstar which is full duplex. run with duplex=0 and linktolink=yes then you will have what you need.
duplex=0 should work for that. The comments in rpt.conf imply ID will work if uncommented. Are you using ASL or HamVoIP?
duplex = 0 ; 0 = Half duplex with no telemetry tones or hang time.
