Shari Pi audio low on transmit
Good morning I’m very new to this setting up my first node. I am running a Pi3 with a stair pi connected to it. I have everything up and running but the audio is really low and I can’t see to find where to change it. I did go to terminal window sudo sa818-menu and didn’t see it there. I do have audio and it’s just low. Any help again im new to this so really dumb it down for me.
sudo simpleusb-tune-menu
Set your audio settings there. you can connect to 55553 to check them.
thank you what settings do you recommend me changing
Option 2 once you connect to enhanced parrot you can fine tune it with ease.
