Joe:
I've done this, it is working great in testing.� Here are the
parts …
1) APP_RPT doesn't support all PL tones (ACID Distribution) ... I
believe that this is the valid decode list (any PL can be
transmitted) …
PL
NOTES
67.0
69.3
Not
Available in AllStar RX DSP
69.4
Not
71.9
74.4
77.0
79.7
82.5
85.4
88.5
91.5
94.8
97.4
100.0
103.5
107.2
110.9
114.8
118.8
DO
NOT USE - 60 Hz Harmonic
123.0
127.3
131.8
DO
NOT USE - DCS Turn Off Code
136.5
DO
141.3
146.2
151.4
156.7
159.8
Not
162.2
165.5
Not
167.9
171.3
Not
173.8
177.3
Not
179.9
DO
NOT USE - 60 Hz harmonic
183.5
Not
186.2
189.9
Not
192.8
196.6
Not
199.5
Not
203.5
206.5
Not
210.7
218.1
225.7
229.1
Not
233.6
241.8
250.3
254.1
Not
2) The method to associate RX and TX tones and have valid decode
of certain PLs� in usbradio.conf� is …
; CTCSS / PL TONES
txctcssdefault= 103.5�� ; default tx ctcss freq, any frequency
permitted, used when RX is quiet
rxctcssfreqs= 67.0,88.5,103.5,136.5,192.8,250.3
����������������������� ; rx ctcss freqs in floating point. must
be in table
txctcssfreqs= 67.0,88.5,103.5,103.5,192.8,250.3
����������������������� ; tx ctcss freqs, any frequency permitted
; RECEIVER CONTROLS
rxctcssoverride=0������ ; Set to 1 or yes to start out in carrier
squelch mode
rxctcssrelax=0��������� ; reduce talkoff from radios w/o CTCSS Tx
HPF
;���������������������� ; (help radios with DTMF Twist)
** Note, you can cross PLs ... when the above receives 136.5 it
transmits 103.5
Like I said, so far it has all worked ... just feed voice and PL
from the discriminator to the AllStar server.� Good Luck!
…STeve - KF5VH
On 7/22/2016 10:29 AM, Joe Moskalski
wrote:
I have a need to setup a community repeater. This is done
easily with a shared repeater tone panel and the like from
CSI. I was wondering if this could be accomplished using
app_rpt. All it would need to do is allow the use of
multiple input and output PL tones. Simply put, when the
repeater receives X pl tone it transmits the X pl tone on
the output and when the repeater receives Y pl tone it
transmits the Y pl tone on the output.
If anyone has done this or has any idea on how this would be
accomplished it would be much appreciated.
Thanks in advance!
