Setup questions. Adding a Shari Pi to my vehicle. Already have one in my shack
I have a Shari Pi inn my shack running Allstar Link 3. I want to put a Shari Pi in my truck as I do a lot of traveling. I am just wondering what the setup process is. Do I just login to my existing account on Allstarlink.org or do I have to create a new one for the second device?
If I am just adding the second device to my existing account, is that a simple process?
Thanks in advance
Andy KE2GBD
You will set it up the same way just with a different node number. You can extend your node number up to 10. For example I have 3 nodes, 294150,294151,294152 Although I really only use two of them one of them is for testing of things so I dont mess up the 2 working ones. Just log into your account and under portal it gives you the option Press Continue to:
Request a new node number from AllStarLink.
Extend a node number up to 10 nodes.
Delete a node number.
If you dont want a similar node number you can request a new number I guess but I think just extending the node number is easier
Thank you for the reply. This was a huge help. Much appreciated.
