Setup issue in ASL 3
Ok, So im sure many have run into this In ASL 3 when you go into the set up from the ASL.3 Dashboard in the terminal mode for setting up the node, it asks for the (Node Password.) One would think that you type in the password u set up to assess the node.! Its not !
You have to use the secret long password that Allstar gives you.
If dont use the password that allstar assigns, you wont be able to register the Node. It should say maybe “Allstar Server Assigned Password.”
Also, I noticed a long time ago that in the normal list of all the Allstar commands list… Its really not clear that when you access a node starting with *1, *2 or *3 you have to type in the node after it .
It should have a note at the top that says , “Any commands that are associated with a node to access or drop, you must type in the node#…”
When prompting for a password the “Node Setup” menu says :
To register node <node#> with AllStarLink we need the
password from "www.allstarlink.org", "Portal", "Node
Settings".
Enter the node password :
Also, see ASL3 Manual : Logins and Passwords
