You have to download your frequency into your radio like you did. When you setup ASL beta 2.0.0, you’ll need to go into your simpleusb.conf and set the ctcss from to no. It’s default is set to usbinvert. Change that and you should be able to hear your dongle transmit. As far as getting programming for that dongle onto ASL so you can change frequencies, I’m not sure.
You do not need to tell the software config what freq you are using.
So that answers the post title.
