I already have a good operating allstar node on one computer. I am installing another node on another computer. I intend to move this node to a different location and wifi. They are both going to be initially on the same wifi as I test this new node. I have expanded my node number on my first server.
Do I need to set this new node up on a separate server because it is on a different computer?
Is the expanded node number going to work on a new server or is that just for that paticular server?
Because they are on different computers (even though are on the same wifi during the testing phase) do I need to change the port number from 4569?
So its always best to setup a new node with a new server, at least in my opinion. Being on the same wifi network yes you will have to setup each node on its own port. Once you move it to a new wifi network you can change it to the same port if you want but you could leave it to whatever you changed it to.
Also, 6-digit NNX numbers behave exactly like 5 (or 4)-digits numbers; ie. completely independent. The only limitation of 6-digit numbers is with regard to moving them between accounts; ie. all of them or none of them.
Yes. In the context of servers under "server settings"; server doesn't even mean a different computer. While virtual machines naturally lend themselves to "but it acts like a different computer"; a ASL3 docker container would be a "server"...and a second container on the same physical hardware also setup as ASL3 on a different node number would be it's own "server".
That being said....the more I look at that page and options the more I'm confused about how to answer:
Because there's nothing I can see tying a node number to a server entry. It's just name, port, gps coordinates, basic info; nothing tying that entry to a node number. So...the expanded node number should work for any of your servers? I have to admit..I'm a bit confused about how it keeps any of this straight.
Yes. That port is the one that opens to the internet; so each one needs a different port.
