Just installed [asl-2.0.0-beta.5-kc1kcc-20210226-amd64.hybrid.iso] on a Supermicro Server and then did the upgrade from the asl-menu.
Planning to do an upgrade for an old ACID version.
Everything appears to be working so far except the syslog indicates this segfault over and over about every 31 seconds.
Dec 1 23:54:38 ASL2 kernel: [ 780.079580] asterisk[798]: segfault at 1a6 ip 00007f66357e5118 sp 00007f6607c162a0 error 4 in app_rpt.so[7f66357d8000+39000]
The betas currently have a bug that will cause a segfault every time a status report is sent. Turning off status reporting will prevent the core dump but prevents reporting to stats.allstarlink.org
In /etc/asterisk/rpt.conf comment statpost_url for each node: statpost_url = http://stats.allstarlink.org/uhandler.php ; Status update
Alternatively, you can go into rsyslog.conf and enter a discard for kernel messages before any of the other logging rules. This doesn’t fix the issue but at least it keeps it from filling your logs up.
