I have build quite a lot of allstar node for our club and have noticed that some micro sd cards had an issue on asl3 platform. It wont boot at all. Ending up running Hamvoip just not to waste that storage card. Tried cloning from a working same size sd card using win32 disk imager but failed. Still wont boot. I know i bought not the most expensive sd card but not the cheapest available in the local market either.
Sounds like you just bought low quality sdcards. Cost isn't how you determine the quality of the sdcard, you should have done that with brand size and quality.
I've never had a MicroSD card not boot after writing an ASL image, and I've probably written 50 of them at least. I have had a few fail while in service, including theoretically reputable brands like Sandisk and Samsung. I trust any MicroSD card about as far as I can throw it... No, wait, that's not a good analogy for as small and light as they are.
My guess is you got a counterfeit SD card. They look like say 32 GB, you can write 32 GB to it but it only holds 4 or 8 GB. Did you get it on Amazon? Was Amazon the seller? The counterfeit cards are a perfect match for the real thing.
The program I always used to check the integrity of SD cards is h2testw. You can identify small cards relabeled as larger ones. When you have such a card, the minute it reaches the end of the ACTUAL capacity, it goes back to the beginning and continues writing, thereby overwriting and corrupting the whole shooting match. Just search for "h2testw"; tests can take awhile, BTW.
ps. Per Allan's reply, just in case you're trying to use ASL3 on an original Pi-Zero v1 or a Pi-2 (or earlier), those are 32-bit processors and not supported by ASL3, which is 64-bit.
