Rxctcssadj not working
Asterisk : 22.9.0+asl3-3.9.3-1.deb13
ASL [app_rpt] : 3.9.3
Inquiry
I wonder if anybody can help with this,
I set up a new repeater and it all seemed to set up fine but after a restart of asterisk I couldn't bring the TX up, found it was not seeing the rx CTCSS, I went back into the usb radio setup menu and did a auto detect CTCSS and it all came up good again. Made really sure to hit the w to write it out and after a reboot again no CTCSS detection.
I had a look at the usbradio.conf file and it is not writing out the rxctcsssdj parameter, everything else is written ok so its not a permissions issue. I tried entering the rxctcssadj manually and although no errors it doesn't seem to make any difference to the way the repeater behaves whatever value i put there.
Since this repeater is a build to replace another one which suddenly has stopped responding to CTCSS I wonder if there is a bug in this section or have I been doing something wrong in my config files that an update has just brought to light.
Any help gratefully received. Thanks
That would be due to an oops that we made in code that was released in v3.7.x. I just filed GitHub : app_rpt : Issue #1088 to restore support for the "rxctcssadj" variable.
Many Thanks, I will wait for the update to come through.
