Hi i am trying to run two nodes on same Network one node i can connect out to stations and stations can connect in but the other node i can connect out to other stations.but other stations can,t connect in help needed thanks
Do you mean to say 2 nodes on 2 server inside the same NAT (same router)
Ham2,
Did the PDF that Mike replyed with help you out?
David
The link to the PDF isn’t working. Is there a typo in the name/link or is the replacement for that document located at this address?
That PDF was retired as we create or move content into the ASL Manual. I’ve added a redirect for that particular URL since it comes up a lot.
Thank you very much!
