2 - VOTER Server Address (FQDN) (voter-demo.allstarlink.org)
3 - VOTER Server Port (667), 4 - Local Port (Override) (0)
5 - Client Password (rptnopl), 6 - Host Password (rptnopl)
7 - Tx Buffer Length (3000)
8 - GPS Data Protocol (0=NMEA, 1=TSIP) (0)
9 - GPS Serial Polarity (0=Non-Inverted, 1=Inverted) (0)
10 - GPS PPS Polarity (0=Non-Inverted, 1=Inverted, 2=NONE) (2)
11 - GPS Baud Rate (4800)
12 - External CTCSS (0=Ignore, 1=Non-Inverted, 2=Inverted) (1)
13 - COR Type (0=Normal, 1=IGNORE COR, 2=No Receiver) (1)
14 - Debug Level (9)
15 - Alt. VOTER Server Address (FQDN) ()
16 - Alt. VOTER Server Port (Override) (0)
17 - DSP/BEW Mode NOT SUPPORTED
18 - “Duplex Mode 3” (0=DISABLED, 1-255 Hang Time) (1/10 secs) (0)
19 - Simulcast Launch Delay (0) (approx 200 ns, 5 = 1us, > 0 to ENA SC)
97 - RX Level, 98 - Status, 99 - Save Values to EEPROM
i - IP Parameters menu, o - Offline Mode Parameters menu
q - Disconnect Remote Console Session, r - reboot system, d - diagnostics
Enter Selection (1-27,97-99,r,q,d) : Using Primary Voter Host (72.0.177.212)
Voter Host DNS Resolved to 96.36.57.202
Connection Using Voter Host (96.36.57.202)
Using Primary Voter Host (96.36.57.202)
Select the following Diagnostic functions:
1 - Set Initial Tone Level (and assert PTT)
2 - Display Value of DIP Switches
3 - Flash LED’s in sequence
4 - Run entire diag suite
c - Show Diagnostic Cable Pinouts
x - Exit Diagnostic Menu (back to main menu)
Enter Selection (1-4,c,x,q,r) : 4^M
Running Diagnostics…
Testing PTT/External CTCSS
Error - Failed to read PTT/CTCSS in un-asserted state
Testing GPS UART
Error - Failed to read data from GPS UART
Testing level at 100 Hz for Normal Audio
^C
— No the LED’s do not come on for GPS/HST
rechecked the wiring all looks right
assuming GTX is transmit that goes to the GPS rx line and vice versa
GPPS pin 7 is labeled as PTT out in the documentation - not sure what that means, I thought it was Gps 1pps?
http://206.212.254.21/unode_docs/rtcm_%20manual.pdf
P2 - DB15F D-Shell connector for the RS-232 (console @57600 bps, DCE) and GPS
1 - NC
2 - Console Transmit Data
3 - Console Receive Data
4 - NC
5 - Gnd
6 - GPS Receive Data (to White TXD on - GPS)
7 - PTT Out (to Yellow Measurement Pulse output - on GPS)
8 - Gnd (to Black - on GPS) all appear common -
9 - NC
10 - Console Request To Send (RTS)
11 - Console Clear To Send (CTS)
12 - NC
13 - GPS Power Output (5Vdc @ 800ma MAX) - (Red on - GPS)
14 - GPS Transmit Data (to green RCV on - GPS)
15 – External Reset
And Yes the gps works fine in windows - not sure what I am missing -
