RTCM squelch tail elimination?
Hello all…
I have replaced a repeater controller with a RTCM and a server.
All is well but for a heavy squelch tail after carrier drop. I am using the unit in simple mode because I do not have an active discriminator output because I am using the RTCM behind a Doug Hall voter.
I have Googled the subject to death and I see plenty of mentioned items regarding simpleusb and usb settings but nothing on voter configuration. Am I missing something someplace?
Thanks in advance for all the information.
You all are some of the smartest folks I know.
Sam K8SN
Simpleusb has nothing to do with RTCMs. You should not have a simpleusb.conf on your system if your only interface is a RTCM.
When you have set the RTCM COR type = 1 the squelch tail comes from your radio, or rather the Doug Hall voter in your case. As far as I know there is no STE setting anywhere in app_rpt or any of it’s channel drivers including chan_voter.
Have you considered connecting RTCMs to your receivers and let them vote in place of the Doug Hall?
Tim
:wq
On Apr 20, 2014, at 12:53 PM, Sam Nabkey sam.nabkey@gmail.com wrote:
Hello all…
Sam K8SN
ohnosec.org
To unsubscribe from this list please visit ohnosec.org and scroll down to the bottom of the page. Enter your email address and press the “Unsubscribe or edit options button”
Tim,
app_rpt can't do STE on receive since that is a transmitter function. But,
chan_usbradio does provide a means to chop off the squelch tail using an
audio delay. This is exactly how it's done on most stand-alone
analog controllers these days.
See the parameter: rxsquelchdelay in the usbradio.conf file.
I can confirm this does work, I use it on several Kenwood repeaters.
Note that you must use flat audio (rxdemod=flat) for rxsquelchdelay to
work, since the "flat" setting turns on most of the DSP code. Setting
rxsquelchdelay=150 will solve most squelch crash issues, in my
experience.
73, David KB4FXC
there is no STE setting anywhere in app_rpt or any of it�s channel
On Sun, 20 Apr 2014, Tim Sawyer wrote:
Tim
:wq
On Apr 20, 2014, at 12:53 PM, Sam Nabkey <sam.nabkey@gmail.com> wrote:
> Hello all...
> Sam K8SN
> App_rpt-users mailing list
> ohnosec.org
> To unsubscribe from this list please visit ohnosec.org and scroll down to the bottom of the page. Enter your email address and press the "Unsubscribe or edit options button"
> You do not need a password to unsubscribe, you can do it via email confirmation. If you have trouble unsubscribing, please send a message to the list detailing the problem.
Dave,
Good to know. Thanks for the correction.
Tim
:wq
On Apr 20, 2014, at 10:01 PM, David McGough <kb4fxc@inttek.net> wrote:
Tim,
experience.
73, David KB4FXC
Tim
:wq
Hello all...
Sam K8SN
ohnosec.org
